Results 1 to 8 of 8
Thread: IG Pool Liner Replacement Questions
    Jun 2011
    Chicago, Illinois
    Default IG Pool Liner Replacement Questions
    I am currently in the process of replacing a 20 x 40 Vinyl Liner that sits in steel walls and what looks to be a vermiculite base. I have removed the old liner and now have a few questions :-
    It appears that the 8 year old walls have a whitish deposit on them - is that calcium / chlorine build up ? and if so should I be looking to remove the build-up before installing the new liner ? will this build cause problems down the line ?. I also have a noticed couple of rust spots on the walls - what is the best way to treat/remove rust from steel walls ?
    I also have a couple of hairline cracks in the vermiculite bottom (deep end hopper), and seeps a little water when it rains - how should I be sealing these cracks ?
    Thanks in advance for your help.
    JJNMRSDAD
    Default Re: IG Pool Liner Replacement Questions
    Hi JJ;
    I'll move your thread into the correct location -- after offering the minimal help I can. (Liners and liner pool hardware is not my area.)
    + The whitish deposit is probably zinc chloride from the galvanizing (zinc) on the steel. If the calcium or chlorine for the pool had been getting to the walls, the result would be rust, not white deposits.
    + The vermiculite is intrinsically porous, and isn't really intended to hold water; it just supports the liner.
    Welcome to the Forum!
    For his 'limited advice' Ben hit the nail on the head!
    For the rust, sand it down, clean the area and use Rustolium, or similar, spray paint to seal it.
    If the cracks in the floor are bothersome or are deep enough to let the liner into them, you can patch them with a THIN coat of hydrolic cement.
    I've got a LOT of experience with liner pools, feel free to 'pick my brain'
    Jun 2011
    Chicago, Illinois
    If the whitish deposit is probably zinc chloride from the galvanizing (zinc) on the steel, should I be looking to clean it up before installing the new liner ?. I will clean up the rust spots and treat. I am think of installing foam around the steel before installing the new liner, that will hopefully keep any rough surfaces from penetrating the new liner.
    Where can I purchase the hydrolic cement ?.
    JJNMRSDAD
    The wall foam is a great idea! If you need any tips on installing it, let me know.
    Lowes or Home Depot might have it, if not, try a masonry supply place.
    SalemCastles Guest
    You can get Hydraulic cement at any home hardware store.
    Jun 2011
    Chicago, Illinois
    How do I remove the Zinc Chloride ?
    If I leave the zinc chloride build up and install the foam wall liner, is the zinc chloride going to cause any future damage to the steel walls ?
  1. Replacement liner advice on above ground pool also where to buy
    By DavidP77 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-30-2012, 06:04 PM
  2. Pool Liner Replacement
    By pigbat in forum In-Ground Pool Construction and Repair
    Last Post: 05-26-2011, 03:34 PM
  3. Liner replacement questions
    By tmredding in forum In-Ground Pool Construction and Repair
    Last Post: 09-27-2008, 12:56 AM
  4. Pool liner died, questions on replacement
    By Mom2Czars in forum Above-Ground Pool Construction & Repair
    Last Post: 04-18-2007, 08:23 AM
  5. Sand floor questions and a replacement liner process
    By The Raddish in forum Above-Ground Pool Construction & Repair
    Last Post: 05-02-2006, 03:06 PM
