Hi Ben!
Well we have had a great summer swimming in our drained and freshly filled newly chlorinated pool and I have used only borax, baking soda, and bleach to maintain it! Here in Mass the nights are getting cold so our above ground, non heated pool has come to its last weekend of use. We are preparing to close it for the winter and I need a cheat sheet version of how to do it with chlorine based pools.
As a reminder, our pool is approximately 10 thousand gallons, oval above ground pool. ( and remember we have used baquacil for the last 10 years prior to this summer's conversion/drain and refill so I am unsure if the closing procedure is different with chlorine). We always use a pillow in the middle of the pool and put a cover on. I usually just drain it to below the skimmer basket and plug up the inlet opening to minimize having to add water next season. And we always take in the motor and cover the filter.
I most importantly need to know about the chemicals to put in and the timing for them in order to winterize the pool. And if you have any other suggestions about my above described plan feel free to let me know!
Thank you again for all of your help - we would never have gotten through the conversion without you! aciam
