Results 1 to 10 of 42
Thread: Need help with starting chlorine after drain/refill
    Default Re: Need help with starting chlorine after drain/refill
    It's pretty normal to have black goo accumulate in skimmers and such. It seems to be related to body oils, sunscreen, and/or mold compounds used in making tabs. I wouldn't worry, though I would wipe it offl.
    The test for metal is vitamin C -- if a crushed damp v-C tab removes it, it's metal.
    Jun 2011
    Massachusetts
    Hi Ben - so it's been a couple of days since I have posted and I just wanted you to know that - I don't have any more questions for you!!!!
    You and your moderators have fixed my pool!!!!! I have had a CC of 0 for the last 24 hours - yes that's right - big fat zero!!!! I almost can't believe my eyes when I look at the non-pink clarity of my water in the taylor comparator tube!!!! I keep testing just to get the thrill of the end result! So thank you for all of your patience and diligence and for sharing all of your knowledge with me - and thank you to chem geek and waterbear and watermom and everyone else who responded to my posts and helped. It has been a truly crazy 6 weeks! You were right when you said it might get better in a week or two - after I added the new water and it still had a CC of 5. And I am so thankful! Just wanted to let you know! aciam
    PS - I still am quite an amateur at managing a chlorine pool so I am sure I will continue to have questions unfortunately for you and since I trust no one but the pool forum here I will be asking them all to you guys! - just in case you were thinking about closing out this thread!
    Congratulations on having finally gotten the pool under control--now enjoy it!! And we wouldn't be closing out this thread...but you're welcome to ask any questions you come up with, just start new threads with them!!
    Happy swimming...
    Jun 2011
    Massachusetts
    Hi Ben - so all has been well with our pool these last few weeks. I went ahead and added a total of 8 boxes of borax with muriatic acid to neutralize per your instructions last week over several days so that I have a semipermanent algistat in the water. ( in preparation for going away) I now have a few questions:
    1. my cya is now up to 60-70; a while ago you told me to switch to liquid bleach from the trichlor tabs I have been using once I hit a cya of 60. But, because of my pool's tenuous history, you had also told me at one point not to use liquid bleach.
    -So, I was just wondering what I should do at this point.
    -And, if I use the liquid do I add it through skimmer?
    -And I think you once said that the cya would decrease by backwashing my sand filter - is that right? and so should I do it and continue with the trichlor tabs since they have worked so well.
    2. we are planning to go away sunday through thursday - I have someone who can come a couple times to test and put bleach into the pool while we are away. Do I have to do anything to prep the pool to leave it now that it has been up and running almost a month and the borax is in. would your advice be different if friends will swim in it while we are away?
    Thank you! aciam
    + When you lose water by backwashing, you replace it with water that has not stabilzer. So, over time, you reduce stabilizer. Chem_Geek has also reported that you may lose as much as 5% per month, via various mechanisms.
    + Add the bleach to the pool. You could add through the skimmer, but you've got to make sure there's nothing in the lines, so it's just easier to add to the pool. Just make sure your pump is running, either way.
    + It's fine to use bleach now, but while you're gone it might be easier for someone just to maintain 2 - 3 tabs in your skimmer. That's what I'd lean toward.
    Jun 2011
    Massachusetts
    Hi Ben!
    Well we have had a great summer swimming in our drained and freshly filled newly chlorinated pool and I have used only borax, baking soda, and bleach to maintain it! Here in Mass the nights are getting cold so our above ground, non heated pool has come to its last weekend of use. We are preparing to close it for the winter and I need a cheat sheet version of how to do it with chlorine based pools.
    As a reminder, our pool is approximately 10 thousand gallons, oval above ground pool. ( and remember we have used baquacil for the last 10 years prior to this summer's conversion/drain and refill so I am unsure if the closing procedure is different with chlorine). We always use a pillow in the middle of the pool and put a cover on. I usually just drain it to below the skimmer basket and plug up the inlet opening to minimize having to add water next season. And we always take in the motor and cover the filter.
    I most importantly need to know about the chemicals to put in and the timing for them in order to winterize the pool. And if you have any other suggestions about my above described plan feel free to let me know!
    Thank you again for all of your help - we would never have gotten through the conversion without you! aciam
  1. High CYA, drain 1/3 refill?
    By fatstogie in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-07-2012, 05:06 PM
  2. Starting with SWCG - no chlorine level
    By brefri in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-15-2012, 02:41 PM
  3. Drain and refill 33,000 gallon gunite pool
    By bugsy0329 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-25-2011, 03:06 PM
  4. Drain AG and refill?
    By Islander2C in forum Above-Ground Pool Construction & Repair
    Last Post: 05-18-2007, 07:02 AM
  5. drain refill and think it's good - your thoughts?
    By west1745 in forum DPD-FAS based testing
    Last Post: 07-25-2006, 10:49 AM
