Thread: Help shorted myself with sand on ag pool installation
    posguy is offline Registered+ Thread Analyst posguy 0
    Bayshore Area.NJ
    Default Re: Help shorted myself with sand on ag pool installation
    If im reading this correctly, the paver is sitting on the ground vs buried ie top of paver flush with original earth. I would fix it as the bottom track is now sitting on an inch of sand vs compacted earth. The cove will very easily wash out, liner will pop and you will have say 18k gallons of water going somewhere. The paver top should be flush with the ground,
    the uprights sit on the paver and the bottom track sits on undisturbed earth, two inches of sand then go in pool.
    Aug 2010
    Pavers have to be flush with the base, there's no way around it and no way to cheat it, your pool will hold a tremendous amount of weight.
    If you think it's alot of work now wait until your done and you fill it up and then it leaks and you have to drain it and rip it apart and fix it.
    Fix it now while you can.
  1. “Solar sensor shorted” REALLY? :(
    By intrepid in forum Pool Equipment & Operations
    Last Post: 02-24-2012, 02:50 AM
  2. New pool installation
    By TonyA. in forum Above-Ground Pool Construction & Repair
    Last Post: 10-07-2011, 11:10 AM
  3. New pool installation.. yes, in September.. :-/
    By phooka in forum Above-Ground Pool Construction & Repair
    Last Post: 09-17-2006, 08:21 PM
  4. New Pool Installation
    By marandy in forum In-Ground Pool Construction and Repair
    Last Post: 07-23-2006, 01:33 PM
  5. Oval Pool Installation
    By hrsdennis in forum Above-Ground Pool Construction & Repair
    Last Post: 07-23-2006, 01:35 AM
