Results 1 to 10 of 14
Thread: Pump Sizing Question
    BigDave's Avatar
    Default Re: Pump Sizing Question
    Thanks Mark, that makes sense.
    Does anyone know(knoe) of a solar control system that will switch the pump to high speed when calling for heat and back to low when it's not needed?
    mas985's Avatar
    Pleasanton, CA
    I think most controllers that control solar will switch to high speed by default. I know for sure that mine, AquaLogic, will definitely do that.
    As for head curves, is the pump you are considering on this page?
    The single speed and two speed versions will have the same head curve on high speed. Low speed is simply a scaled version. But looking at these pumps, I would like to see a little more flow rate at 50' of head. But you might ask the forum if anyone is using one of these pumps for a two story solar install. But if you want to be safe, I would go with an IG pump. Something like a 1 HP SuperPump, I know would work.
    Mark
    BigDave's Avatar
    Right now I'm trying to convice myself that a variable speed pump is the way to go. Install a flowmeter and set the pump to meet the flow requirements of filtration or the solar based on test and not "Wild Guess" estimate of piping / filtration / heat system in operation before being built.
    cons:
    Expensive
    pros:
    Potential to save on electricity ( I haven't calculated what it would take to break even on that )
    Use only what we need to run the gear not use what the pump requires
    Maintain optimal flow rate for each configuration
    Can be adjusted as our needs change
    Can self prime making it useable if we do get an IG
    Keeps me from having to go through estimating the requirements of a system that doesn't yet exist and living with it later
    Sounds like I'm taking myself into it.
    BigDave's Avatar
    PoolDoc
    I will send the curves if I get 'em. All I've gotten so far has been and auto answer email "We have recived your inquiry and will respond as soon as possible..."
    mas985's Avatar
    Pleasanton, CA
    Again, the head curves are on this web page if you don't want to wait for Hayward. It is a table under "Performance Data"
    Mark
    BigDave's Avatar
    I got that Mark and thank you very much. That table is partly what's pushing me toward Variable Speed - I'm not there yet, but trying to work my head around it.
  1. Question about Pump/Sand Filter Sizing
    By NTL1991 in forum Pool Equipment & Operations
    Last Post: 08-11-2012, 10:39 PM
  2. Pool Filter & Pump Sizing Question?
    By zooba72 in forum Pool Equipment & Operations
    Last Post: 06-17-2012, 10:02 PM
  3. Question on PB's pump sizing
    By txborn in forum Pool Equipment & Operations
    Last Post: 10-27-2006, 01:26 AM
  4. Pump Sizing Question
    By liz+3 in forum Pool Equipment & Operations
    Last Post: 06-27-2006, 09:45 PM
