Thread: Haywood Pump seems to suck air
    Jun 2011
    South Central PA
    Question Haywood Pump seems to suck air
    Just installed a new Haywood pump to out AG pool. It seems to be sucking air. A whirlpool appears by the return and I see air bubbles in it from time to time. I also seem to have a leak that appears to be at the filter. I have tightened the fittings and there is still a drip. Any advice would be appreciated.
    Default Re: Haywood Pump seems to suck air
    Whirlpool by pool return -- where water *returns* to your pool doesn't indicate a leak.
    Air bubbles might indicate a suction leak -- a leak in the piping or gear between the skimmer and main drain, and the pump.
    Fixing leaks is often hard, when you are there, but doing it remotely is harder. Can you take pictures of your pump, filter and piping, and email them to poolforum AT gmail DOT com? (Large pictures; I'll shrink them and discard what's not pertinent.)
  1. Replies: 1
    Last Post: 08-02-2012, 11:04 PM
  2. Haywood Bumping Problem
    By minasha1 in forum Pool Equipment & Operations
    Last Post: 07-29-2011, 10:36 PM
  3. Haywood Pump Loud
    By jojosail in forum Pool Equipment & Operations
    Last Post: 06-25-2006, 11:00 AM
  4. help with understanding Haywood DE filter.
    By tundraSQ in forum Pool Equipment & Operations
    Last Post: 06-14-2006, 01:09 PM
  5. Question on Zeobrite using Haywood filter
    By gkbloom in forum Pool Equipment & Operations
    Last Post: 05-08-2006, 07:31 PM
