Thread: Gray Cal-hypo?
    Yeggim is offline Registered+ Thread Analyst Yeggim 0
    Aug 2010
    Philly
    Default Gray Cal-hypo?
    Anyone ever have Cal-hypo turn gray? I have a couple pounds of it in one pound bags from last year. I used one and it was white. When mixed in a bucket it turned milky white as usual. Opened another one--it was gray and turned milky gray when mixed in bucket. I'm assuming that this is normal as the chlorine content degrades?
    Aug 2010
    Philly
    Default Re: Gray Cal-hypo?
    Thanks Mom. I used it anyways. Testing afterwards seems to indicate less ppm's of FC than expected. No untoward aftereffects noticed. Funny thing though. When punching in "gray" and "calhypo" I came across this. Seems a ship caught fire and and a lawsuit was filed against a CalHypo manufacturer. The manufacturer is the same one that made the Calhypo that I asked about. Good thing I threw it in the pool--eh?
    My experience has been that cal hypo gets gray and lumpy as it gets old.
    Try to avoid storing it from year to year! But if you do, using it in the pool is the best way to dispose of it.
    Honesdale PA
    I've kept the stuff for up to 3 years or so when I wasn't using it that much and never saw any color shift or obvious decrease in strength. Original container tightly closed in a poolhouse that does get hot in the summer.
    Aug 2010
    Philly
    Yep, gray and lumpy. It was packaged in 1lb. bags. Sold as SUPER SHOCK-IT. I was always sort of a frugal guy, so I didn't want to waste it. This forum is a perfect fit for me. Even more so now given my current economic situation.
  1. difference between cal hypo and sodium hypo (from bleach)
    By kasatpoolforum in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-20-2010, 08:12 PM
  2. Gray and Fluffy
    By cpmart in forum Dealing with Algae & Slime
    Last Post: 07-13-2006, 10:54 AM
  3. Brownish-gray stains in vinyl IG pool
    By gumbeaux71 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-22-2006, 01:57 PM
  4. Gray Plaster - Gray Portland or Dye?
    By jabre in forum In-Ground Pool Construction and Repair
    Last Post: 03-31-2006, 08:40 AM
