POPP! Pool Owner Patience and Persistance!
Evening numbers:
FC 0.0
CC 2.0
pH 7.3
TA 180
Headed out to get more acid to keep the pH at 7.0, but glad to see that the CC finally is in the 1 - 2 range. Thanks for the reminder about POPP Carl.
Taylor K-2006, IG Vinyl 26,000g, Sand filter 275 lbs, 3/4 HP Hayward Super Pump II, CYA over 100, Using 12.5% bleach
18'x36' rectangle 26K gal IG pool; Liquid Chlorine 12.5% ; Sand Filter 275 lbs. sand filter; Hayward Super Pump II 3/4 HP pump; 23 hrshrs; Taylor K-2006; delivered via truck; summer: ; winter: ; iPad; PF:4.6
On 6/17 Janet wrote:
"So..his (Ben's) recommendation was to break it (the ammonia) down slowly with the lower doses of bleach, until you start getting CC readings of 1 or 2--at which time you can up the doseage and go ahead and get rid of it. So...stick with the 6 gallon dose for now."
This is the 2nd day that my CC was 2 or lower. Is it time to up the dosage of bleach?
Here're this evening's numbers:
FC 0.0
CC between 1.5 and 2.0
pH 7.4 (put in 30 oz dry acid)
TA 190
Thanks!
If you want to go to a 9 gallon dose, that would be OK.
If you can, use muriatic instead of dry acid. It's cheaper, stronger, and better for your pool. Of course it's more noxious to handle -- gloves, glasses & watch the fumes when you pour! But you're going to need to lower your alkalinity, so keep pushing the pH back down.
PoolDoc / Ben
Thanks Ben - I'll up the dose to 9 gallons starting with this evening's dose.
FC 2.5 (first time I've seen FC in a while)
CC 2.0
pH 7.3 I switched back to muriatic acid this morning.
TA 190-200
Evening numbers:
FC 0.5
CC 1.5
pH 7.2 (put in more m. acid)
TA 180
Tonight the dosage increased to 9 gallons of 6% bleach - water is quite green, visibility about 20"
Ordered a couple 5 gal carboys from Uline and found a local cleaning supply that sells 12.5% bleach for $2.75/gal. so I can keep up the dosage until the water clears - it will seem like alchemy when it does!
Morning report:
FC 10.5
CC 2.5
pH 7.2 (added more acid)
TA 190
Water still green with low visibility.
