Hi,
First time poster, but I have lurked around this and the TFP forum before.
First, a little intro. I live in SE Texas, near the coast, about an hour from Houston. I have an inground pool, approx, 18,000 gallons. Gunite/plaster. Had the plaster re-done last year. My filter is a sand filter, my pump is a 1-HP pentair whisperflo. I installed the pump/filter myself around 2006, before that I had a DE filter.
I bought this house second hand, the pool was originally installed in '88 or '89. Through the years I have done my fair share or more of upkeep..actually way more than I would like.
The big problem I have been having this year is that the water just stays cloudy and murky. I have tested the water myself several times, the pH and Alk. are all within the normal ranges, as is the hardness. It seems that the water will try to clear up a little, and then go right back to being cloudy. I'm using tons of chlorine and backwashing the filter when it needs it (going by the discharge gauge).
I have several thougths on the causes. One thing I'm suspecting is that my filter is not working correctly either due to internal problems or maybe the sand needs to be changed. I changed the sand once before a few years ago but it didn't really help. I have heard that the selection valves get messed up and let the water bypass the filter, or at least a side stream.
Second thought is that it's algae that I'm not clearing all the way out. Normally when the pool gets infested with algae it turns green and you can see it on the walls /surfaces. This really looks more murky than anything else.
Other thoughts are that my chemistry is not right and my tests are wrong. I'm going to take a sample to have checked this week, but other than that any tips or anything would be appreciated.
