UPDATE: I ran the filter through the night and the water is clear with a slight hint of a "greenish brown" discoloration. I tested the water using a DPD test kit. (I'll be upgrading to a FAS-DPD soon) and my pH is still around 7.5 and cl is low. What is my next step? I know that I need to add cl should I use an inline chlorinator or should I drop a couple of 3" tablets in the skimmer? Based on the discholoration that I saw yesterday do I need to add another dose of metal free before adding cl? I've noticed a couple of small areas of algea forming on the walls as well. Should I sweep the pool and add an algea preventer? I have noticed that this site reccomends polyquat for algea prevention. Is polyquat a brand name or the base chemical that is in all agea preventers?
