Results 1 to 10 of 22
Thread: Just pulled cover off.. green swamp water
    Jun 2011
    Question Just pulled cover off.. green swamp water
    So we had some problems with the winter cover this year and all the crap on the cover went into the pool. Now we have green swamp water in the pool. We had this one other year and had to clean the filter every hour for about three days before we could see the bottom. This is a 4-foot deep, 27' round above-ground. We have a DE filter. Is there a way, or are there certain chemicals I could use to get the water clearer faster? Thanks for the help.
    Default Re: Just pulled cover off.. green swamp water
    That very same thing happened to me one year! Not a lot of fun, but actually pretty easy to clean up. Lots of chlorine (bleach) will do the trick. Scoop out as much of the debris as you can and run your pump 24/7, cleaning the filter as often as is needed. If you can post a current set of water testing results taken with a drops-based kit, someone here can better advise you. If you don't have a kit, let a pool store test for you but just don't buy all the stuff they will try and sell you. The kit we recommend is the Taylor K-2006 or 2006C which is the same kit with larger quantities of some of the most used reagents. Click on the Amazon link in my signature below to find it.
    Slade;
    *Live* algae plugs DE filters rapidly; *dead* algae does so MUCH more slowly. So, kill the algae.
    As Watermom says, it will take lots of bleach. I'm guessing you are about 15,000 gallons (27' x 3.5' water depth), so each gallon of bleach will add about 4 ppm of chlorine. For a swamp, you probably need to think in 16 ppm / 4 gallon doses.
    Do this:
    + Go to Walmart and purchase a cheap OTO/phenol red test kit and about 24 gallons of bleach. You can also get a few boxes of borax and some stabilizer if you can find that there.
    + Make SURE (really, really sure!!) that if you have a feeder, tab feeder, Nature 2 or other gizmo the tabs, filler, cartridge, etc is REMOVED.
    + Run the pump / filter 24/7
    + Add your bleach THROUGH the skimmer. This will kill the algae on the DE, first before the bleach reaches the pool and will help relieve the rapid plugging of the DE.
    + Meanwhile, keep scooping and vacuuming.
    + Test the pool 1 hour after each bleach addition; repeat the dose EVERY TIME the chlorine goes below 3 ppm.
    + If the chlorine is still high, but the OTO does not turn ORANGE, and the filter is stopping up, add *one* gallon via the skimmer, to see if that will relieve the high pressure. If not, wait 15 minutes and then clean the filter again.
    With a DE filter, you should be able to clean your pool up pretty quickly (a day, maybe?) if you can keep working on it.
    Ben
    Jun 2011
    Hey thanks a lot, I will try that. I was reading some other posts and it seems like all these years I could have been backwashing my filter instead of taking out the grids and hosing them off. Obviously I'll have to hook up some extra plumbing to make this work, wish I thought of it earlier!
    Jun 2011
    Instead of bagged shock, is it better to use bleach? If so, what's the ratio, one bag of shock = 1/2 gallon of bleach?
    Quote Originally Posted by slade8200 View Post
    Depends on what your water testing readings are. I personally just use bleach for shocking and for daily chlorination, but if your CYA is low enough, you can shock with dichlor.
    Dunno. Plus, there are many types of bags of shock of various sizes.
  1. Opened for first time with old loop loc mesh cover green swamp
    By Gretzky99 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2013, 10:01 AM
  2. 27,000 gallon green swamp HELP
    By ms dean in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-29-2012, 02:38 PM
  3. Green Pool / Swamp complete with frogs...
    By JenLM in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-13-2011, 03:11 PM
  4. cover off - green water - pump broken
    By masspool in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-09-2010, 03:58 AM
  5. Cover blew off some, green water on top now in the pool
    By traceyb in forum Above-Ground Pool Construction & Repair
    Last Post: 09-02-2008, 10:56 PM
