Thread: Sta-rite filter replacement
    May 2011
    Default Sta-rite filter replacement
    How often should I replace my Sta-rite System 3 modular filters? I've my filters for about 9 years and clean them a few times a year. They seem to still do the job, no holes or rips in them. Is there a reason to replace them at some point?
    Thanks!
    Default Re: Sta-rite filter replacement
    Wow, a question with a really, really easy answer: if it's working, don't fix it. I had a terrible experience with those filters in commercial situation, but it sounds like they are working great for you.
    Ben
    Midwest
    9 years is a pretty good run on a filter cartridge. I have two sets. I use my older set, 7- 9 years old, for start up and change them out after about two weeks. Then my newer cleaner set, will then usually last the rest of my 4-5 month season.
    Halogen pool supply was quite a bit cheaper than my pool company.
  1. Aqua Rite motherboard replacement wiring
    By noelbowman in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 12-23-2012, 11:38 PM
  2. Sta-RiteŽ System 3 Air Bleed Filter
    By meghanW in forum Pool Equipment & Operations
    Last Post: 08-24-2012, 10:33 PM
  3. Sta-Rite System 3 Cartridge Filter - Can I convert to sand using the same housing?
    By sqwarecocci in forum In-Ground Pool Construction and Repair
    Last Post: 04-22-2011, 07:45 AM
  4. Sta-Rite Dura-Glas 1HP replacement
    By cschnurr in forum Pool Equipment & Operations
    Last Post: 04-24-2008, 10:25 PM
  5. Laterals in Sta-Rite System 3 sand filter
    By Area Man in forum Pool Equipment & Operations
    Last Post: 05-27-2006, 10:00 AM
