Results 1 to 10 of 26
Thread: bleach calc
    Jun 2013
    Missouri
    Question Re: bleach calc
    I am having the same problem with the link. I keep getting "unexpected error" from both IE and Firefox. Would running Windows 8 have anything to do with it? Frustrating. I need to bring my FC level of 3 up to my CYA level of 63. I don't know how much 8.25% of bleach to add. Also my CC is .5 If I add the amount of bleach I'm supposed to tonight, at what point can I add Borax to raise my pH level?
    Above ground Intex round 24' x 52", 13,600 gallons, Hayward VL Series sand filter and pump, Missouri resident
    Default Re: bleach calc
    In a 13,600 gallon pool, each quart of 8.25% bleach will add 1.5ppm of chlorine.
    You can add the Borax and the bleach one right after the other with no problem. I do it all the time.
    Hope this helps.
    Jun 2013
    Missouri
    Smile Re: bleach calc
    It helps tremendously. Thanks for the quick reply.
  1. Bleach Calc Error
    By ePoolUser in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-01-2006, 07:02 PM
  2. bleach calc ??
    By geneskaf in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-14-2006, 05:15 PM
  3. Bleach Calc
    By michladny in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-14-2006, 11:54 AM
  4. bleach calc
    By sisie5 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-27-2006, 05:43 PM
