Results 1 to 10 of 58
Thread: Algae loves my pool
    May 2011
    Houston
    Default Re: Algae loves my pool
    OK, I still have to wait until my kit comes in the mail. Hopefully by Thursday. Also, I have an AG pool, so how do you aerate it like the directions describe to raise the pH back up? Just curious if you have done this? Also, I'm using that pool calculator by In the Swim to determine how much acid. Is that a reliable calculator?
    Thanks a bunch!
    Apr 2011
    virginia
    aeration will work the same in AG pools; you can simply direct your returns up some, to churn the water on the surface, or maybe even a small fountain effect
    I haven't used that calculator specifically, but most of them give you similar doses- the key behind Acid is to adjust in steps IMO, don't dump all at once but use 1/2 - 2/3 of the dose, retest in an hour (with the pump running) and adjust more if needed; depending on pool size and TA, you may need more acid than called, but its easier to add more than to take it away; if you overdo acid, you have to add something else to compensate, then you end up on a seesaw!
    May 2011
    Houston
    I got my test kit in today. The pool looks fan-swimmin-tastic!!
    CYA 30
    FC 4.4
    CC 0
    TA 250
    pH 7.6
    I am using the pool calculator to lower my pH to 7.0 in order to get my alkalinity down. It says for a 13k pool to add 46oz of muratic acid. Should I add that much or do only like 30 for now. My husband is working on the aerator part. LOL
    Also, how soon after I add that acid can I let the kiddos swim? 2 hours?
    And...since my CYA has lowered quite a bit, I'm going to use the rest of my trichlor tabs in a floater to maintain cl levels for now. Once I run out, then I'll use my bleach. What do you think?
    Hope ya'll have a great Memorial Weekend!! Be safe and thanks again for the advice.
    May 2011
    Houston
    Been putting in muriatic acid a little at a time. This morning here are the readings.
    pH 7.3
    TA 210
    Guess this is going to take a while. Also went ahead and put in those tabs to maintain the chlorine which is right at 5.2. Guess everything is going ok. Didn't feel the need to test CYA again. I will when I use up all the tabs.
    I went ahead and subscribed for a year. Ya'll have been super! Thanks again.
    You don't have to be quite that cautious -- add enough acid to get down to 7.0 . . . and then add a little more. As the alkalinity 'bleeds off' (as carbon dioxide) the pH will go back up.
    Thanks for the subscription!
    Ben
    May 2011
    Houston
    The pH is at 7.0 and the TA is now 200. How long does it take for the pH to get back up to at least 7.4? I have a strong spa jet like current bubbling in the middle of the pool aerating.
    13k AG.
  1. Avoiding Algae / Removing Algae
    By PoolDoc in forum Dealing with Algae & Slime
    Last Post: 07-24-2011, 10:40 PM
  2. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  3. Green algae? Mustard algae?
  4. My pool loves low TA
    By BillyBumbler in forum Dealing with Alkalinity and Calcium
    Last Post: 02-07-2007, 09:55 PM
  5. Who loves their Polaris 380?
    By jenmenke in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-26-2006, 01:23 PM
