Thread: shocking pool
    Mar 2011
    Birmingham, Al
    Default shocking pool
    I am wanting to shock my pool again. I am not sure which pool shock i need to buy. Regular shock, shock plus ?? I want to use something that will increase my CYA. I am having trouble getting it up. It is low <30.
    Default Re: shocking pool
    Sort of depends on your pool volume. If your pool is large enough, so you can use it up, I'd suggest going to Sams Wholesale, and getting a 50# bucket ($105) of dichlor (sodium dichloro-isocyanurate) -- that's about 60% chlorine and 50% stabilizer (I know those don't add up -- you don't want to know why).
    But, you don't want to store the stuff till 2012, so if you've got a small pool, you'd be better getting something smaller from Walmart even though it costs more (a lot more!) per pound.
    But, do NOT get the 'goop' or "plus" shocks -- the ones with trichlor, clarifiers, water balance chems (usually borax), etc. -- those are ALWAYS a bad value, and often bad for your pool as well.
    Ben
    May 2010
    Route 100
    One thing to check, if you are experiencing issues keeping your CYA level up, is that you may possibly have a pool leak (especially if masked by an autofill device) or it could just be you've had plenty of rain and water replacement. How are you testing your CYA levels?
    Moderator at another pool maintenace forum
    24' Round AGP, SWG, 0.5hp pump, 250lb sand filter,
  1. looking for help in shocking my vinyl pool.
    By lmclark in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-24-2013, 01:42 PM
  2. Shocking a pool?
    By Hoops in forum --cleanup--
    Last Post: 06-09-2013, 11:59 PM
  3. Question about shocking the pool
    By Dooley11 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-10-2011, 05:53 PM
  4. Shocking a pool
    By CanuckPool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-07-2006, 08:27 AM
