We have a 28,000 gallon, in-ground, gunite pool, with cartridge filtration at the house we rent. We have spent more than $300 in the last 15 days and are worse off than when we started. We have had our water tested at the pool place daily. Today our test results are: FC 2.0; TC 2.0; CC 0.0; pH 7.4; alkalinity 100 ppm; cyanuric acid 150 ppm; total dissolved solids are 1100 ppm.
When we started we had green algae. We took in a water sample every day and followed, to the letter, all the recommendations of the pool guy at 2 different pool companies. At about day 3, one of the recommendations was to use floc. We were told to vacuum the stuff off the bottom of the pool the next morning -- which we did. We did not know we were supposed to "vacuum to waste". Before we started to vacuum, the water was clear on top with fluffy dark green stuff on the last 2" of the bottom. After we vacuumed, we had lots of tiny particles in the water. We took another water sample to the pool people and they said to add soda ash, along with shocking the pool. After adding the soda ash, the particles became lighter green, but are still there. Since then, we have used several different brands of clarifers, all according to directions. We have seen only the slightest bit of change. Every day, at least twice a day, we change the filter out and thoroughly clean it, and we vacuum every day. Today, we have finally, for the first time since using the floc, turned off the pool pump and are trying to see if these superfine particles will settle to the bottom or not. (We have also used double socks on the sump basket except of course, when vacuuming.) The filter does catch green, just not enough to make any real difference. The socks also catch enough to color the socks, but not enough to make a difference in the water.) The pool is still extremely cloudy. The above listings are our chems for today. I just want to be able to use the pool. Surely 2 weeks is too long for this problem not to be solved. Can anyone tell us what to do to be able to use the pool? (My husband finally understands he has to keep the chlorine tablets in the little floating thing - so - if we can get it back to normal, we don't think we'll have any more problems.) I'm going to try to post pics in the pic gallery. Don't know if I have permission to do that.
