I tried posting yesterday but did not see my post appear. So my apologies if this is a repeat.
This past Sunday I set up an Intex 12' x 30" pool. I think it holds 1718 gallons to fill line.
Testing after filling Sunday night was:
TC 0-0.5
PH 6.8
TA 30 ppm
I think I may have added too much liquid bleach (1 gallon) and too much baking soda (10 oz dissolved in water). Also have a sock with 1/10 of a box of Borax hanging in the pool.
Pool read Monday am:
FC 5 (or higher)
TC 5 (or higher)
PH 8.2 (or higher)
Acid demand: to drop PH to 7.5 required 6 drops of R-008
TA 60 ppm
Pool read Tuesday am:
FC 5 (or higher)
TC 5 (or higher)
PH 8.2 (or higher)
TA 70 ppm
The test kit I got did not have CYA. So I guess I should order CYA stand alone test kit?
Do I need to just add some Muriatic Acid to lower PH? And take cover off the pool to allow chlorine levels to lower by themselves? Wanted to try to use the pool this Saturday if possible.
Thank you
