I have an intex 24' x 52 pool, approx 12k gallons,633t filter says 2500 not sure what that is measurement wise. I'm having problems with spring startup. Pool went from swamp green to a light cloudy green and won't go blue.I've used the HTH super shock approx 6-7 bags and about 4 gallons of bleach in the last 2 weeks. Keeps raining so can't get a handle. I use the 6 way HTH kit. Chlorine is plus 10, ph is now 7.2, alk I stopped at 55 drops and it still didn't go red just purple,hardness 30 drops and just went purple, cya never lost the black dot probably doing test wrong. Thanks for the help in advance. crazy cat lady!
