I am a pool owner for 10 years but always struggled with keeping Chlorine up...I have stabilized in the past but did not often check CYA levels.
Last year I kept getting no chlorine or very low chlorine, low pH and high TA readings on my test strips no matter how much chlorine and pH up I added and then the water got very cloudy.
I finally broke down and went to the pool store where they told me my TA was off the chart high and gave me "low and slow" to improve it. I was able to get the pool clear after hundreds of dollars in their chemicals.
I went out and bought several brands of strips including a digital test strip reader and realized that the pool store was right as I had pH and TA, and I think I must have had a bad batch of strips at one point.
Here is where I am at now:
Taylor 2006 ordered via amazon tonight to get more accurate results.
Chemical Values the best I can tell from 3 types of test strips (all reading the same, and are the same as the pool store):
pH 8.1
TA 300+
CYA 0-30
Chlorine 0
I just removed the cover with semi clear green tinted water with silt on the bottom. (My pool has overhaning oak trees and I use a mesh safety cover)
I will verify values with my new Taylor kit.
My real question is:
Should I stabilize before taking on the pH and TA?
Should I wait until put bleach in until pH is ok?
What should my plan of attack be???
I plan on trying the BBB method but I just do not know where to start at this point since my numbers are so "off".
(It is really crazy that I have not had a good handle on my pool for 10 years. I avoided pool stores because they always wanted me to spend hundreds no matter what my values were. I have always been good with 3" tablets and basic shock and occasional pH up until the last 2-3 years when I struggled to get a chlorine level no matter how much chlorine I put in my pool, even though the water was clear.)
