Re: PolyQuat and Shocking with Chlorine
CarlD
(BTW, if this gets more technical I'll move it to the China Shop.)
Perhaps you didn't notice, but we are already in The China Shop! I started the thread here because I knew the issue was controversial and not for newbies, though I wasn't sure how technical it was going to get (of course, I tend to make things go that way...:D ).
And your point is quite valid of whether the chlorine breaks down PolyQuat, thus defeating the purpose of using it, or if it combines with PolyQuat to form a potent compound to inhibit and kill algae. Hopefully we'll find the answer to that soon.
Richard
Jakebear
Also noticed pH is up a bit to 7.7 from 7.5 before the Quat.
If everyone is seeing a pH rise when the chlorine gets used up by the "full" amount we have been seeing (the 3:2 molar ratio), then this gives an interesting clue as to what may be going on. The process of producing a combined chlorine, as with a chloramine or a chlorinated organic, is a basic (alkaline) process. In the case of ammonia, one of the hydrogen gets replaced with chlorine and produces water. Since the weak acid (HOCl) is thus consumed, this is a slightly basic process. In the case of creating a chlorinated organic, the process would be similar if this were a nitrogen with hydrogen attached, but PolyQuat has methyl groups attached to each nitrogen. So, a possible scenario is to replace the methyl group with chlorine thus releasing methanol. This is again a weakly basic (alkaline) process.
Achieving breakpoint is an acidic process that is so strong that the net of the above formation of a chlorinated compound plus breakpoint is a slightly acidic process. However, this is for the simple process of breaking ammonia. I am not clear as to what exactly would happen in breaking PolyQuat.
What doesn't make complete sense is that a replacement of one of the methyl groups, analagous to producing a monochloramine, would have the chlorine used up in a 1:1 molar ratio while if both methyl groups were replaced, analagous to producing a dichloramine, then the chlorine would get used up in a 2:1 molar ratio. Yet we are seeing a 3:2 molar ratio that is normally associated with achieving breakpoint of ammonia. Very strange indeed...
Richard
chem geek
I just wrote an E-mail to Buckman Laboratories regarding this issue of chlorine breaking down PolyQuat so we'll see if they respond. I'll keep y'all posted. We'll get to the bottom of this eventually.
Richard
I guess you haven't heard anything yet from Buckman Labs. From all you've written it sure sound like Quat may be a waste if you follow the BBB method.
fcfrey
I haven't heard from them yet and just sent a reminder E-mail. I doubt that PolyQuat is a waste at normal chlorine levels. The chlorine may only combine with PolyQuat relatively slowly at normal levels -- perhaps over a weeks time (given that it takes around 1-2 days at high chlorine levels) and the PolyQuat may be quite effective at preventing algae during that time. Also, I don't know yet if the chlorine combining with PolyQuat reduces its effectiveness (i.e. does it form a combination substance that is still useful or does it breakdown PolyQuat rendering it useless). So we'll still need to wait and see what Buckman says.
Richard
I received the following response from Buckman Laboratories:
Code:
Mr. Falk:
Sorry about the delay in getting back to you. I've been checking into some
literature references and trying to contact some of our water treatment
specialists to find some answers to your questions.
1) The Polyquat 60 product that you mentioned is typically used along with
chlorine at normal use concentrations (low ppm levels of both substances) in
swimming pools. Chlorine provides a faster kill of bacteria, while the
Polyquat 60 provides better control of algae as well as better water clarity.
The different advantages of these two pool treatments complement each other.
2) While chlorine and Polyquat 60 have been shown to have very little
interaction at low concentrations, there can be some reaction or degradation
at higher concentrations. For example, Polyquat 60 and bleach should not
be mixed neat, as an undesirable reaction would be expected to occur.
3) In an alkaline solution containing an oxidizing agent, the polymer that
comprises the active ingredient in Polyquat 60 can be cleaved at the sites of
the quaternary ammonium groups, forming shorter polymer chains. These
shorter chains are still cationic; and, according to some internal lab data
here at Buckman Laboratories, these shorter chains retain their biocidal
activity. As the chains become shorter, the Polyquat test kit will not longer
respond to and detect them; however, the lack of a response by the test kit
does not necessarily indicate that the biocidal activity has been lost.
4) In our recommended approach for winterization, the pool should be
"shocked" with about 5-10 ppm chlorine to destroy any lingering oxidant
demand, to remove any residual ammonia or chloramine, etc. After a
couple of days, adjust the pH back to 7.2-7.6 and add Polyquat 60 at the
maximum rate allowed by the label. This approach allows you to have the
maximum benefit from both chemicals.
If you have any other questions, please do not hesitate to contact us.
Tom McNeel
Principal Scientist
Buckman Laboratories International, Inc.
So there does appear to be consumption of chlorine by the PolyQuat (shock chlorine has high FC levels and increases the pH of the pool) and this is probably cleavage at the Nitrogen site, but the remaining chains are still effective as an algaecide. However, the recommendation is to first shock with chlorine (mostly to get rid of most organics and/or ammonia in the pool) and then wait for the FC to return to normal levels and make sure the pH is in the normal range. Then, add the PolyQuat in the recommended amount for closing the pool.
In addition to the E-mail, I talked with Dr. McNeel and asked about the method of action of PolyQuat on algae and he said that the cationic nature of the molecule (that means it has positive net charge) binds to and interferes with the negatively charged cell exteriors of most algae and bacteria and prevents the normal transport of food into the cell and waste out of the cell. This process is somewhat slow so it's fine for inhibiting algae, but not quite fast enough to quickly kill bacteria so chlorine is still required for disinfection. This method of action is for the hydrophillic (i.e. "water loving") PolyQuat molecules. There are other quarternary ammonium compounds that are hydrophobic (i.e. "water hating") that operate with a different method of action, but we didn't get into details on that.
He also said that while PolyQuat inhibits and kills algae, it does not harm people, either through skin exposure nor consumption (i.e. drinking pool water that has some PolyQuat in it). [EDIT] Dr. McNeel sent a follow-up E-mail saying that after adding PolyQuat, the circulation pump should be kept running for at least 24 hours to thoroughly distribute it through the pool. My guess is that the heavy molecular weight of the PolyQuat (it's a long-chain polymer) makes it slower to diffuse so lots of circulation is needed. [END-EDIT]
Thanks,
Richard
chem geek
Another option is to use 50 ppm Borates instead of PolyQuat and that seems to have the advantage of inhibiting algae without breaking down from chlorine the way that PolyQuat *may* do. It will be interesting to see if Borate levels are maintained over the winter with those people who are now using it.
Richard
I don't close my pool for the winter but the water has gotten colder (about 45- 50 deg. now if I don't turn on the heater) and my borate levels are still at 50 ppm. I am running my FC at about 3 ppm in this colder weather (swg at 4% and pump run time of 6 hours) and pool is still clear and sparkling. Have not added acid in 2 months and pH is still 7.6. From what I have seen so far borates, when properly dosed, seem to be very effective at reducing sanitizer demand. We shall see what happens as the winter progresses.
