smallpooldad
As regards CyA and SWG I had the same experience with the BBB method at 35 CyA.
Apples and oranges.  You cannot compare a manually chlorinated pool with a SWG any more than you can compare a pool using ORP control to one that is not.  IF you did not have the controller and raised the CYA and turned down the output you would find what I say is true.:)
I am not sure what misinformation you are referring to?  I have always tempered my responses with the caveat that I am clearly nowhere near the level of expertise of the professionals on this forum.
