Beautiful pool.
What are you going to use to seal the flagstone ? (I need to do that myself).
Beautiful pool.
Thanks,
Im probably going to use a color enhancer made by StoneTech as I can get it locally and have talked to someone that is happy with it.
StoneCare International also sells a stone color enhancer that is also good. http://www.stonecare.com
Another sealer that is supposed to be good is called Sure Seal. http://www.suresealusa.com/USA%20Products.html
Just depends if you want the flagstone to look like its wet (dark) or if you dont want it to change the appearance at all. Most all color enhancers also are sealers but you can get sealers that dont change the appearance of the stone.
