Re: Pool looks like a swamp
jdw, while the pool store's advice would probably work - killing the algae with a sufficient dose of bleach and letting it settle to the bottom would probably also work. Ben had a 'riff' about... 'any chem you add to a pool will do something, often the desired result, but will also cause a problem that you didn't expect' -- The point is that if you just start adding 'Miracle X' chems, there will be a 'backlash' problem - POP (pool owner patience) is most often the BEST way to deal with a problem [something that took months to cause usually can't be cleared up in a day!!:cool: ]
waste
Thanks for the reply. Should I keep it at shock levels until it is completely clear?
jdw-tx
By saying swamp, that implies the pool is green to some extent. If you have visible algae, leave it there for sure.
For swamp busting advice, check out this thread.
http://www.poolforum.com/pf2/showthread.php?t=7622
Spensar
I would call it more cloudy than green. When I brush the pool I can see a fine light brown mist, like dirt, which I assume is some type of algae. Does this make a difference? I'm trying to keep it at 20ppm and run 24/7.
That is a pretty good description of mustard algae.
