FAQs & Guides: Testing & Adjusting Pool Chemistry
__________________________________________________
Getting the RIGHT test kit for your pool
Taylor K2006 instruction videos on YouTube
Testing pH with phenol red, when chlorine levels are above 10 ppm
Interpreting the CYA test (photos)
Using a cheap OTO kit for high chlorine levels
from the K1000, PS200, HTH 6way for HIGH chlorine levels
Using muriatic acid safely, to lower pool pH
Some men need a pH meter, due to partial color blindness
Use the embedded test images to check to see if you do!_____________________________________________
All Purpose FAQs & GuidesHow to Use the PoolForum Effectively__________________________________________________
PoolForum Terminology & Abbreviations
Beginner's Guide to Pool Chemistry and the BBB Method
PoolForum Rules
Archival pages . . . of varying utilityUsing distilled water to extend test kit range__________________________________________________
