Forum: Pool Construction, Equipment, Operations, Seasonal Care (P)
Physical pool care & construction sections HERE!
Sub-Forums Last Post
  1. If you are getting, or have, an Intex type pool, this is the place for questions about site prep, setup, pumps, filters and operations.
    Forum Actions:
    Forum Statistics:
    • Threads: 281
  2. Questions and comments about problems with building or fixing your pool -- whether you DIY, or hire a contractor -- go here.
    Forum Actions:
    Forum Statistics:
    • Threads: 2,301
  3. Got an AG pool question? I'm no expert, but someone else here might be!
    Forum Actions:
    Forum Statistics:
    • Threads: 1,465
  4. Pumps, pipes, filters, lights; covers, valves, heaters, coolers; filling and draining . . .
    Forum Actions:
    Forum Statistics:
    • Threads: 3,626
  5. Spring startup; new pool startup; fall shutdown & winterization.
    Forum Actions:
    Forum Statistics:
    • Threads: 900
  6. Polaris, Kreepy, Letro, Barracuda, or hand-to-hand combat with your pool!
    Forum Actions:
    Forum Statistics:
    • Threads: 724
  7. Questions about all sorts of pool equipment that is electronic, or controlled by electronics
    Forum Actions:
    Forum Statistics:
    • Threads: 60
  8. Pools and pets are an uneasy mix; and skunks, skinks, ducks, dogs, biting bugs, and swimming snakes weren't the pool visitors most owners expected.
    Forum Actions:
    Forum Statistics:
    • Threads: 129
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
