This is very scary. New white plaster pool. Pool filled with 1/4 of our wellwater (Texas Hill Country) and two truckloads of water from local water company. Pool is about 3 weeks now. I will give all details even though they may not have anything to do with how this happened:
Purchased new chlorine tabs at Home Depot: they were different from what our pool company had given us (blue specks imbeded in them...a filler) thought this might be the problem so took these back and got 100% pure chlorine tabs.
Realized that chlorine was set at full blast on equipment dial (pool tech must have forgotten to tell us to turn it down) so lots of chlorine.
We've had to add meriatic acid a few times...at his advice as we are trying to get water levels to settle down.
Daughter had sleepover and many girls playing in pool over this weekend.
Sunday, pool started getting covered in what appears to be a dark green stain. Does not rub off AT ALL.
Stains are on bottom two stairs..bottom of pool (not as dark in shaded end but still there) seems to be about 6 inches from surface of pool and all over bottom.
Can actually see where one of the girls sat in the spa and on a step...this is puzzling.
I did read a post on metals in pool water and crushed vitamin C in a sock. IT WORKED ON THE STAIN WITH LOTS OF RUBBING.
I got this "metal out" product from pool store and according to directions for my size pool, (14000) etc added that to the pool last night.
This morning still the same.
My fear: could the gunnite be showing through or could this be a plaster problem? So scary when one has invested in an expensive pool and now it is not as it should be. The installer of the pool is very baffled. He has been installing pools out in these parts for over 10 years (well water) and has never seen this. Even he is very concerned. HELP!
Chrlorine is too high to have water tested yet. Waiting for it to go down.
. I would be very leery of the chlorine tabs with specs in them. Make sure they don't contain copper. You also don't want to use the chlorine tabs that are trichlor as they will raise your cya even more. You should take a look at the chlorine forums and the algae forums - you will see that good old fashioned bleach really does work. The best suggestion I have for you is to get a good test kit so you can test your own water and learn how to take care of your pool yourself and not be at the mercy of pool stores. Do a lot of reading on this site, and ask any questions you have. Everyone here loves to help
