Testing with high TC
					I've read that testing PH with a high TC result isn't valid/accurate...  My TC is 17.5, 0 CC (had to shock to kill a slight green tint on the floor this am, over did the bleach a bit
).  CYA is < 30 but not zero (can't see the dot when the tube is full).
Question is: aside from PH, what other tests are affected by high TC?
			Evan S.
AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
