Results 1 to 10 of 18
Thread: Tagelus diverter / spider gasket
Threaded View
    May 2010
    Illinois
    Question Tagelus diverter / spider gasket
    Hi - I've got a Tagelus TA-50D sand filter that needs a new spider gasket. I'm getting water leaking out of my backwash hose. I understand that this also may be the cause of dirt getting back in my IG pool (please confirm). I've pulled off the top part of my filter and seen the bad gasket. It does appear to be glued on. Now, I suppose that I could scrape out the old one & glue a new one in, but I haven't seen a part number for it, and Pentair only sells the diverter. I'm happy to buy a new diverter (as opposed to the whole thing) but I can't figure out how to get the old diverter off the handle / spring thing. I know my local pool store won't give me a straight answer. Could someone help? Thanks in advance.
    UPDATE - so, 2 more things. At the pool store today I found out that once I pull off the handle / valve assy. (which I had w/ me) if I rotate the handle between the Closed setting & Backwash setting then I can take the handle off by removing a phillips head screw. My new diverter will be here Wednesday - stay tuned. Also, when I reinstalled the handle /valve assy. - what do I use to lube the spider gasket? Pentair wants me to use 3M 847 Gasket Grip but don't I want to use the pool lube / teflon stuff? Pentair specifically says "Don't Use Vaseline"?
    Thoughts?
    -Rob
  1. Need a Hayward spider gasket
    By Bkirrane in forum Pool Equipment & Operations
    Last Post: 05-28-2012, 10:30 AM
  2. Spider Gasket
    By markphin in forum Pool Equipment & Operations
    Last Post: 05-21-2012, 01:18 PM
  3. Spider Gasket for Hayward GM142
    By Wayne LaBanca in forum Pool Equipment & Operations
    Last Post: 08-06-2006, 08:26 AM
  4. Spider Gasket - First Obsticle
    By Sprint54 in forum In-Ground Pool Construction and Repair
    Last Post: 05-15-2006, 10:31 AM
  5. Replacing Spider Gasket
    By let_her_flicker in forum Pool Equipment & Operations
    Last Post: 04-22-2006, 11:49 AM
