Results 1 to 10 of 12
Thread: Ok, my lesson learned the hard way.......
    Default Ok, my lesson learned the hard way.......
    When you add new sand or zeolite to your filter, MAKE SURE YOU START IT UP IN BACKWASH MODE!!!!!
    Since my pool runs year round and I never drain my lines, the only time the filter was started up from ground zero was when I was a brand new pool owner 8 years ago. So--when my nice pretty new liner was in place and my pool refilled, spider gasket replaced in the multiport, 25 lb bag of zeolite put into the filter to replace what the filter had pushed into the pool the year before (different story, now I have a new filter), I threw the power switch with the valve in "filter" mode, and.....voila!!! a horrendous cloud of yellowish-greenish dust from the new zeosand plus all the crud that was in the old sand from over the winter flooded my pool, and in about 30 seconds it was so muddy you couldn't see the pattern in the bottom of the shallow end, let alone the deep!!!!
    Although a lot of the crud was the sand itself and settled out, the "dust" part of it simply wouldn't--so after almost 3 weeks of continuous filtering, even with DE thrown in, it wasn't clearing. Water numbers were perfect, held it at shock for almost a week just in case. We have since replaced the sand filter with a new one, new zeolite, started up in backwash and interestingly enough, all the crud that came out with the backwash was the exact color my pool water has been.
    I am proud to say now that even though I am NOT a proponent of clarifiers/floc except in extreme situations, we were down to draining and refilling again (30K gallons) or try the clarifier. Put it in last night, ran pump all night, this morning it's crystal except the very bottom "layer" of water in deep end, and even then I can clearly see the pattern (and color) in the deep end, for the first time since the initial pump start.
    So....battery on my Poolbuster vac is charging, have new Polaris bag installed, and will be vacuuming up the remaining sand in the morning. Pressure on my sand filter is up 2 psi from yesterday, so it's apparently doing the trick.
    I'll never make that mistake again!!!!
    Lehigh Valley, PA
    Default Re: Ok, my lesson learned the hard way.......
    What a nightmare this must have been!
    I didn't know about starting a newly refilled sand filter in backwash mode. I, too, learned from your mistake. It's good that the clarifier worked and you have your nice clear water back.
    Oval 12.5K gal AGP; Hayward 19" sand filter; Pentair Dyn 1 HP 2sp pump on timer
    [URL="http://www.ellerbach.com/Pool/"]My Pool Pages[/URL]
    California
    Chlorine is great at clearing up a pool of organic debris including dead algae, but some types of chemicals (or particles like fine sand) don't get oxidized well from chlorine and are better dealt with by using a clarifier or flocculant. If you go a week with shock levels of chlorine with little visible improvement and very little drop in chlorine overnight, then it's usually a sign that chlorine isn't going to work to clear the pool.
    Connecticut.
    Dont feel bad!
    Had my liner installed, plumbed the filter up myself. Even backwashed the fresh sand like you're supposed to.
    Fired up the filter and let it go 24/7 for a few days, yet the water looked like yours.....fine floating particles that werent algae, more like sand. I couldnt figure it out for the life of me.
    Standing next to the pump/filter one day, I realized.....I had plumbed the multiport backwards!! Talk about a "DUH" moment. Re-plumbed it correctly, and just like you the stuff still wouldnt filter out.
    Threw in some clarifier before leaving for work one day. Came home after work and the water was crystal clear. I hate using floc/clarifier, but Im also impatient so sometimes Ill give in and use it to help clear up the pool faster (like this years opening). $9.00 for enough for 2 uses, I guess thats not really getting pool stored is it?
    No, I don't consider that pool-stored! Just as long as you didn't also bring home a bag of calcium flakes!!
  1. Learned My Lesson
    By karrde97 in forum Dealing with Algae & Slime
    Last Post: 06-06-2007, 08:07 PM
  2. I need a pump lesson please
    By gordonhyde in forum In-Ground Pool Construction and Repair
    Last Post: 09-13-2006, 02:42 PM
  3. Pool Reno Lesson
    By simsjim in forum In-Ground Pool Construction and Repair
    Last Post: 07-28-2006, 09:39 AM
  4. Adding CYA (Stabilizer) My Way - Lesson Learned
    By PatL34 in forum Pool Equipment & Operations
    Last Post: 06-03-2006, 06:23 PM
  5. DE Filters - Lesson Learned
    By rhosk in forum Pool Equipment & Operations
    Last Post: 05-10-2006, 03:59 PM
