Hi,
I had bought a book for building a spa from www.custombuiltspas.com and it is excellent. It shows how to build one using concrete blocks. Some people either tile the spa or just the top. And the rest of the inside is sealed and painted with special paint for this.
He even includes plans for building a lager spa for a swim spa. How reliable would this be? I was thinking of building one about 20' long and 12' wide kind of shaped like below. The floor of the pool would be solid concrete. Can you pour concrete on a slightly sloped ground and keep it from running downhill? I guess as long as its thick enough?
Any suggestions? I wanted to use this method so i can create my own shape, add seats, etc. I would use rebar down the concrete blocks with concrete poured down in them.
