The saga of cracked pool.
this started about 2 years ago when we purchased a new home with a pool (20x40 33K gal). As we all know it was hot real estate market then. We liked the house and saw the pool was marked asis so we asked why and were told that a few tiles were missing. We purchased the house without inspection with a bidding war about $60K over asking price. Later after settlement we found out that the pool had popped out of the ground but settled unleveled and a large (1600 sq ft) deck has been poured level with the unleveled pool. There were cracks circling the shallow end of the pool all around, the pool beam was cracked etc. Lets not get into the details of the fight with the previous owner which is still ongoing. I got 6 people to come in to give me estimate of repair. 3 said you need to tear it down and build a new pool. 3 said it can be repaired. of the 3 one will not give any warranty and one did not give an estimate and said he is too busy! The third gave me a two year warranty and said the cracks are not too serious. That the one I used. At the end of 2005 season they tear down the beam and cut all the cracks, fixed the beam and put hydraulic cement in the cracks new tile and coping and replastered at the beginning of the next season. Upon filling the pool the cracks appeared again in the new plaster. After going back and forth with the contractor whom I knew underestimated the severity of the cracks I researched and found Torque lock http://www.torque-lock.com/ and made a deal with the contractor (I felt sorry for the guy - I have a small business and can sympathize with him) that I will pay for the staples (about $2000) as long as he will install them and he is still on the hook for the two year warranty! They installed the staples end of last season and I suggested to him to check under the pool for cavity. He drilled holes in several areas and found cavities under the shallow end which he pumped cement and sand in to fill and plasered the entire pool again. We filled the pool up yesterday and NO Cracks! Lesson learned! A little overdoing and over engineering is a good insurance for trouble later. I don't know if it was the Torque Lock or the filling the cavity that fixed the problem but the combination did the job.
regards
Amir
- You may not post replies
- You may not edit your posts
Forum Rules
