Our pump started making a much louder noise, although it isn't continuous. It sometimes sounds almost normal, but you can still hear a different sound. Also, the motor housing gets hot to the touch. Most importantly, our electric bill jumped about 50% last month and we think it's related to the pump.
It's possible the pump was run without sufficient water for a short period due to a leak in the pool (new pool, incidentally).
The electric bill couldn't be related to the heat pump as it hasn't worked since the day it was installed last July (It's a pentair hp 1200 r). Just thought I would throw that in.
It's a Hayward Super Pump, 1.5 hp.
Is it possible for a pump to use more electricity if it's malfunctioning?
Any help is appreciated. Thanks.
) If you have the puddling/ leak I was talking about, please post back and I'll give you all the part #s to pick up to change the shaft seal and make it 'good as new'.
