Am lead to believe, after reading a while back an American Ground Water Association article, that aerating water by passing bubbles through it releases Iron and other minerals into the air, therby removing Iron from the water. Is this true?
If so, then what size/sort/strength pump and how many lines and outlets would be needed in pool that is 32' x 9' with 9000 gallons? How long should it take in hours?
I realize this a weird question, but any solution for those of us with Iron issues is helpful.
Aloha
