Using hypochlorite dilution to measure pool volume
I'm not sure this is the right place for this post, so please feel free to move it.
I have a free-form, plaster & concrete pool, shaped like an ameba, with varying depths in different parts of the pool and a curved bottom. As a result it has proven difficult to accurately estimate the pool’s volume using conventional algorithms.
The estimate of pool volume has been a source of considerable disagreement with my (former) pool company, since I believed their calculations were too high and tended to amplify the amount of chemicals that got dumped into my pool! When I decided to look after the pool myself I felt it was essential to get a better estimate to minimize chemical additions.
When I obtained Ben’s testing kit and read the various posts about using regular bleach as a source of hypochlorite , I realized that it should be possible to back calculate the volume of my pool using proportions. Knowing the volume of bleach used, its concentration and measuring the peak concentration after dilution in the pool should provide an estimate of the volume of my pool.
The question I ask myself and now ask the experts from the forum is what are the sources of error and therefore how reliable is the result?
Data and calculation - I have performed this experiment a couple of times and come to approximately the same answer. I provide data for one experiment.
PoolVol= (Bleach Concentration * Bleach Vol *1,000,000) /FC change
PoolVol= 0.06*5.4375*1000000/11.5 = 28300 gallons
Pool data: pH 7.5, FC 3.5, CC 0,Alk 100, Cal 160, CYA 50, Temp 76F
Sampled from different parts of the pool after sunset.
1. 15 minutes after addition pH 7.8+, FC 14
2. 30 mins pH 7.8+, FC 16
3. 45 mins pH 7.5, FC 15 (pH corrected with muriatic acid)
Assumptions and sources of error
Chlorine consumption – assumed neither sun nor organics (CC=0) significant at this time
Dilution – Appears to occur within 30-45 minutes with liquid bleach. (Hayward 2 HP superpump turns over pool approx every 6 hours)
Measurements – 1230 gallons +/- per 0.5 ppm FC (i.e. per drop of FAS-DPD#2 solution at 10mls pool water)….in hindsight probably 25 mls would be more accurate
- 220 gallons +/- per oz bleach (not measured but assumed to have vol on label)
- 283 gallons +/- per 1% bleach (anyone know how often is store bought bleach is 6% exactly?)
Conclusion My pool company guestimated 40K gallons and I, using dimensional estimation, calculated about 35 K. The dilution method gives about 30K gallons.
Anything big I have missed? 30K seems about right, but I would value some thoughts from the forum.
- You may not post replies
- You may not edit your posts
Forum Rules
