Results 1 to 1 of 1
Thread: need to get pump to pull from bottom
    bkny1055 is offline Registered+ Thread Analyst bkny1055 0
    in the Deep Deep Deep south
    Default need to get pump to pull from bottom
    I have several questions ?? Newbie here <--
    1.There is a red Valve that i dont know where to set it to
    straight up it pulls from the skimmer
    to the right it also pulls from the skimmer
    2.which way pulls from the bottom of the pool
    3.which way should i use the valves for best results
    4.What do they mean by " backwash "
    5.Where do i buy the the kit everyone here is always talking about
    here are pics
    (((((((((WHICH WAY VALVE NEEDS TO BE SO IT GOES THROUGH FILTER)))))))))
    Best Board Ever thanks guys for the Help.
  1. Scrutinize my cart before I pull the trigger???
    By Shawdaddy1972 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-06-2012, 03:44 PM
  2. Help...about to pull my hair out or tear down the pool!!!
    By butterfly26_78382 in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-06-2011, 04:11 PM
  3. Help! I'm ready to pull my hair out!
    By mortimay in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-27-2011, 09:06 PM
  4. SC-60: How to pull the power cord
    By CAL7 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-29-2011, 08:12 PM
  5. Won't pull water in when backwashing
    By adamsmom1 in forum Pool Equipment & Operations
    Last Post: 05-07-2008, 06:58 PM
