Results 1 to 4 of 4
Thread: What to Do with Old Bleach Bottles?
    Default What to Do with Old Bleach Bottles?
    Quote Originally Posted by waste
    Maybe someone else will post with a creative solution to the empty jug problem.
    (from Re: Sodium Dichlor triazetene??? )
    Sell them on Ebay to cat-fishermen using trot-lines?
    Actually, this question has been asked a number of times, and probably deserves some serious consideration.
    The bottles themselves can be recycled, in many areas.
    I just checked the ones here, and they are HDPE*. Probably that's true of all of them. You can look on the bottom for the triangular symbol
    and the "HTPE". Most large, and many medium, cities have a center for collecting re-cycle-able plastics.
    Here's a page, from the state of NY, about distinguishing types of plastics. And, another one, from the doe.gov
    Before you return them, you should rinse all them twice in the pool (fill with a cup of pool water, cap, shake, empty into the pool, repeat), and remove as much of the label as is practical. You can the squash the bottle, and stash them in some giant black leaf or trash bags, till you're going near a recycle center.
    Do NOT recycle the cap -- it's not HDPE, and is impractical to recyle.
    There's something else to consider, however. "Sometimes it takes more energy to recycle plastics than it does to use all new materials" (DOE). And, it may be important to know that the Berkeley, California "Plastics Task Force" is against plastic recycling - they want you to use glass! (But, they probably don't want you to have a pool in the first place.)
    There is another idea for using them.
    Many private and public agencies, are encouraging people to stockpile enough food and water for a month or more. The reasons include a recognition that Katrina-like disasters are inevitiable for all sorts of reasons, including changing weather, terrorists, the San Andreas OR New Madrid faults, or even a bird flu epidemic. Chlorine bottles are inherently sterile when you empty them. You might want to rinse once with tap water, refill, and then add 2 - 3 drops of bleach back in, before storing. A couple hundred of these, stored under your house, might be very helpful sometime in the next five years. If you do this, you might want to date them, and then sample one of the oldest every so often, to check for problems. Also if you fill them only 3/4 full, the bottles are much more likely to survive freeze-thaw cycles.
    If you want to think more about the preparation concept, here are two CDC pages:
    http://www.cdc.gov/flu/avian/outbreaks/current.htm
    http://www.pandemicflu.gov/plan/tab3.html
    Maybe others have better ideas!
    Ben
    "PoolDoc"
    * High Density Polyetheylene
    Ben
    Default Re: Sodium Dichlor triazetene???
    Here's another thing you can do:
    You can buy liquid chlorine at a pool store in a 5 gallon carboy at 12.5%. Buy a carboy spigot, too, so you don't make a mess.
    Fill up ten 1-gallon jugs half-way with tap water. Then fill them the rest of the way from the carboy. Presto! You have 10 gallons of 6% bleach to be stored in a cool, shady spot. 6% doesn't break down as fast as 12.5%
    If you aren't sure of how strong it is, add 1 ml of the liquid chlorine to 10 liters of water (that's 5 soda bottles) and test it like it was your pool. The FC reading is the strength of the LC you bought.
    Be sure to use tap water, not pool water, and, VERY IMPORTANT!!!! Put the water in FIRST, then the LC. It's very, VERY dangerous to do it the other way around.
    Also keep an extra jug of water handy in case the LC splashes so if it lands on you, you can flush it immediately.
    The carboy is a deposit bottle. I paid the deposit on 2 a few years ago and re-use them and re-use them.
    'Course, Ben may tell you this is a bad idea, but until he does...I'm doing it!
    Since the LC here is about $17/carboy, that works out to 6% bleach at $1.70/gallon--and the pool stores sell it for $2.49/gallon. Also cheaper than 6% bleach in our local supermarkets. Less waste, too, which was the whole thread of this thread.
    Default Re: What to Do with Old Bleach Bottles?
    I filled 5 of them (the 1.5 gallon size) with sand, then topped that off with water to remove all the air. They weigh about 22-24# each. Makes great weights for the pool stairs when attached with cable ties.
    Omaha
    If you live in a cold winter climate, Fill the bottles ( minus labels) about 1/2 full with gravel and cap tight (enough gravel so that just the cone top stays above water when submerged). they make great freeze gizmos (ice pressure absorbers) for your pool in the winter.
  1. Empty Bleach Bottles
    By Cannonball in forum General Interest
    Last Post: 06-04-2006, 04:58 PM
