Results 1 to 10 of 11
Thread: New to Chlorine, was in baquacil hell, any advice please
    Jul 2006
    Default New to Chlorine, was in baquacil hell, any advice please
    Hello,
    This forum is excellent, wish we had seen it before we spent two years in baquacil hell. We had to drain our pool and start from scratch due to the evil baquacil empire. Too long to write, but it was the easiest way for us to get the water clear.
    So now we have just filled the pool back up and my question is now what? Is there a specific type of chlorine to use? We have an oval above ground and I just want to swim in it at least once before we have to close it here in MA.
    Any help would be greatly appreciated. Thank is advance.
    Coadys Mom
    Morris, IL
    Default Re: New to Chlorine, was in baquacil hell, any advice please
    So you now have fresh water? I think that now is the time for you to change your filter medium, if it is sand then change the sand, you know...
    As for chlorine, we all use plain old bleach from the store. I just buy the cheap bottles from WalMart. You should post up some test results from your water once you get it going too.
    Jul 2006
    Hi,
    Thank you for your reply. Yes, we have fresh water. So, I can just by regular bleach? Thank you again
    Morris, IL
    Yes, regular bleach is the ticket. The problem with Baquacil though is the "goo" that it puts in your filter. You need to get all of that out. What type of filter do you use? You need to clean it out.
    Jul 2006
    We do not have a sand filter, we have a Haywayd that you put powder in. My husband has been dealing with the pool but this last baqaucil episode really ticked him off so I am trying to help out. That's why I'm not too proficient with the pool lingo and the equipment we have. Is there a tool or equaition that I can use to help me figure out how much bleach to add?
    Thank you again for your help!!
    Morris, IL
    You can download a program called BleachCalc and it will tell you how much bleach to add, among alot of other great things. It comes configured for metric measurements, but you can change the settings in the top somewhere. You can also see at the top that you can calculate the gallons of your pool, which you will need to enter in to get the correct bleach content.
    Once your bleach stays overnight, you should take the DE filter apart and clean it, and put new DE in it.
    Here is a nice summary: click me!
    Northern Kentucky
    Here is the link to BleachCalc
    Get BleachCalc 2.6.2 here:http://home.earthlink.net/~mwsmith70...achCalc262.exe
    Download this handy progran to calculate your pool's needs. You can click More calcs and settings to change from Metric to Imperial to get US gallons.
    ETA: Sevver beat me to it!
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
    Jul 2006
    Default More questions from a newbie
    Hello,
    Thank you to all you helped in my thread below. I have some additional questions that are probably so simple but I am so unsure and don't want to scew anything up especially since we just finished draining the pool to get rid of the evil baquacil.
    Any help is greatly appreciated.
    Can anyone give me what a good ppm would be for a 15x26.5 oval abouve ground?
    I suppose I need to test the water first before I add teh beleach or shoudl I had some,then test? It just finished filling about an hour ago.
    Can I just egt a test kit from like Wal-Mart for now?
    Thanks again!
    Morris, IL
    Default Re: More questions from a newbie
    You need to know what the CYA is for the pool in order to determine the ppm chlorine. I think that you had said in the other post that your CYA was 0, if that is so you should pick up some Cyanuric Acid also because you will need to raise it to between 30 and 40. I figured the pool at around 13000 gallons, and the bleach calc said to add about 3 pounds of Cyanuric Acid, I would start with half and wait a couple of days to test again.
  1. Baquacil to Chlorine help
    By billjan in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-25-2012, 11:16 PM
  2. Baquacil to Chlorine conversion
    By telesforos in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 06-16-2012, 08:51 PM
  3. Baquacil CDX to Chlorine conversion
    By gbwarrior in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 02-07-2012, 03:59 PM
  4. Coverting from Bacqui-hell I mean Bacqucil to Chlorine
    By Mariza in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-10-2006, 11:40 AM
  5. Baquacil to Chlorine Conversion
    By godstreasures1 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 04-20-2006, 11:09 AM
