Results 1 to 10 of 19
Thread: anyone have any experience with the Skim Shark?
    waldreps is offline Registered+ Thread Analyst waldreps 0
    Lake Park, MN, USA.
    Default anyone have any experience with the Skim Shark?
    Just curious if anyone has any experience with the Skim Shark battery operated skimmer that floats and moves randomly around on the surface to pick of debris? It has a rechargable battery and In the Swim has it for $69.99. Anybody out there used it?
    Thanks,
    Stacy
    Lake Park, MN, USA.
    leejp is offline Registered+ Thread Analyst leejp 0
    Upstate, NY (Dutchess County)
    Default I'll pass... but I do have a leaf/pine needle problem so...
    I can't imagine any battery powered unit like this would have enough power. I do have a leaf/pine needle problem so I'm thinking about this:
    http://www.thepoolskimmer.com
    This thing looks pretty simple and it actually looks like it may work. I'll try it for $60.
    There is a similar product that according to the folks here (before the server went down) doesn't work and is a waste of money so stay away.
    http://pooldevil.com
    26,000 Vynil Liner L Inground
    Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
    Poolvergnuegen thepoolcleaner Pressure Side Cleaner
    Loop-Loc Mesh cover
    Dec 2005
    Austin, TX, USA.
    Talking Re: anyone have any experience with the Skim Shark?
    leejp, please post your experience with the Poolskim when you get it! I agree, it looks worth the try. Thanks for volunteering to be the one on the forum to shell out the $60 to try it out :-)
    Default Re: anyone have any experience with the Skim Shark?
    Quote Originally Posted by jabre
    Will do...
    You'll have to wait until the end of May though... that's when the cover comes off here in Upstate, NY (after most of the pine needles and the norway maple spinners have come down).
    Loop-Loc Mesh cover
    Lake Park, MN, USA.
    Thanks for the suggestion. I'm also interested in your results. I only have one skimmer in my 18x36 inground pool and it has a hard time keeping up. I'm looking for something to supplement it.
    I don't think the skim shark actually sucks the debris. I think it just moves around and the debris ends up in the "mouth" of the shark. So the battery power just causes it to "swim" around. I'll wait for your results though on the pool skim. Thanks.
    Winter Springs, FL
    Then, there is the Polaris LCS. See it at http://www.polarispoolsystems.com
    Look under accessories, then LCS.
    I have one (also a Pool Devil and wll probably get a Poolskim, too - I am desperate for more skiming action) and the results are still out. It goes on the line for a suction cleaner and needs the cleaner to move it around the pool. I found that my 1.5hp pump would not drive the LCS and Hayward Navigator enough to get very effective action. Since the LCS is on the line before the Navigator, it reduces the suction to the cleaner. There is an ajdjustment, but I have found I do not have enough power to effectively drive both. I will be swapping my 1.5hp for a 2hp soon, so maybe it will improve.
    gwrace1 is offline Registered+ Thread Analyst gwrace1 0
    Dec 2005
    South Central Texas
    Default Re: I'll pass... but I do have a leaf/pine needle problem so...
    Well I decided to be a guinea pig for all three products. I ordered the Skim Shark, Pool Devil and PoolSkim. I'll report back results after doing some testing with each.
    33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
    Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
    Aqualuminator with Fountain -- Solar Pool Lights
    Pool Pictures at the link below
    http://community.webshots.com/album/548241672nKeuyR
    Dec 2005
    South Central Texas
    Well I received the Skim Shark from In the Swim this weekend. About the only thing good I can say about it is, it's cute. The little propeller barely has enough power to do anything but give it a very slow push across the pool. The plastic filter basket has holes large enough so that a lot of small top debris like pollen and insects (ants) go right through it. There is no suction for the debris. The leaves are gathered into the mouth during the slow movement across the pool. After charging it for the recommended time I could only get about an hour's worth of run time. I would not recommend this product to anyone unless you like it's "cute appeal" Mine is going back to In the swim on Monday. It's not a real pool cleaner.
    Dec 2005
    South Central Texas
    Well I received my PoolSkim yesterday only to be disappointed again. The product only comes with 2 inch pvc fittings even though it is marketed as working on both inground and above ground pools. If you have an above ground pool with standard 1.5 inch return fittings you will have to order their adapter for $5 plus 2 dollars shipping. I plan to make a trip to Lowes on the way home to see if I can come up with some fittings to make it work.
  1. Please help me remove what looks like watery skim milk in my pool.
    By Doug1540 in forum Dealing with Alkalinity and Calcium
    Last Post: 06-21-2013, 05:30 PM
  2. bioguard skim mor (skimmer sock)
    By belbog in forum Pool Equipment & Operations
    Last Post: 09-06-2008, 08:18 PM
  3. LIL shark
    By rayh78 in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-12-2008, 08:03 AM
  4. Pool Shark vs. Polaris ATV
    By Arizonaoldman in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-26-2006, 10:36 AM
