Thread: Non Chlorine oxidizer ????
    pool newby is offline ** No working email address ** Thread Analyst pool newby 0
    Default Non Chlorine oxidizer ????
    Hello,
    With a 8600 abg pool my numbers are:
    FC - 3.5
    TC- 4.5
    CC - 1.0
    CYA- 48
    TA- 140
    PH - 7.4
    My water is crystal clear, and no obvious problems. Looks like I might need to shock, since my pool gets all day sunlight and quite a bit of usage from 2 adults and 2 kids. I have some non chlorine oxidizer shock that reads:
    active ingredient:
    potassium monopersulfate....44.7 %
    Inert ingredients....................55.3 %
    Percent active oxygen............4.7 %
    The label says it will clear up combined chloramides and other wastes. I didn't buy this stuff, it came with my pool start up kit.
    I'm thinking this won't substitute for regular chlorine shocking, but I'm wondering if it will hurt anything putting in my pool, or exactly what's it's purpose is?
    thanks
    Bob P
    pool newby
    E Tn
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: Non Chlorine oxidizer ????
    MPS (potassium monopersulfate) will not eliminate chloramines already in the pool. It works by keeping an excess of oxidizer in the water to, in theory, burn off organics before they combine with the chlorine and become chorlamines. It is not as strong an oxidizer as chlorine and will also show up as combined chlorine and total chlorine on testing unless a special reagent is used to eliminate the interferance from it. The above info is right off the DuPont website. They manufacture just about all of the MPS out there under the brand name Oxone which is then repackaged by the pool chemical companies. They developed the product initially.
    IMHO, it is of little use in a chlorine sanitized pool and is really only useful with Bromine as a sanitizer because it actually reactivates bromine in the water.
  1. Aqua Silk™ Chlorine-Free Shock Oxidizer
    By Lawrosa in forum Pool Chemicals & Pool Water Problems
    Last Post: 01-04-2013, 12:16 PM
  2. Leslie's Oxidizer II (old)
    By axntdsgn in forum Pool Chemicals & Pool Water Problems
    Last Post: 11-26-2011, 02:07 AM
  3. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  4. skimmers & oxidizer's????
    By ChampC in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 06-18-2006, 09:47 PM
  5. ProTeam Shock & Swim (oxidizer really necessary?)
    By bboehm in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-27-2006, 11:00 AM
