Results 1 to 10 of 15
Thread: Homeade Pool Steps?
    Lightbulb Homeade Pool Steps?
    Hi,
    I have an in-ground liner pool with no steps - just ladders. My dog swims in the pool a lot, but cannot get out by herself. I can't afford to buy the fancy steps for $350-$600 right now and I don't really need them. I just need one medium-sized step (she's a big dog) so she can get out without my assistance. I bought a new product I thought might work, but it was too flimsy - it was a plastic ramp that you tie to the pool deck. I keep it to save wild animals that fall in the pool, which is good, but not my goal.
    I want to make my own step to put in the floor of the pool. I'm wondering what materials are okay for inside a pool, ideas for weight, anything? Any suggestions? Is it a good or bad idea?
    Thanks!
    haze_1956 is offline ** No working email address ** Thread Analyst haze_1956 0
    nj, usa.
    Default
    A few suggestions to start, other I'm sure will add.
    Seems to me the simplest thing to do is to extend the first step of one of the existing ladders into a platform. Enough for the dog to climb onto then out of the pool.
    Using plastic materials and stainless steel screws should make it water safe.
    What kind of Ladders do you have ? Could you provide a drawing if possible?
    Default how about...
    a plastic bin with a concrete block inside it, seal the bin up (stainless screws) so the block can't fall out and place it in the pool where you want it, it should sink, if not, add a block.
    To take it out, unscrew, take out block (s) bin should float.
    prh129 is offline Lifetime Member Widget Weaver prh129 0
    Rehoboth, MA
    Default
    I was thinking about taking Matt's suggestion one step further and suggest using a milk-crate with the bricks tied to the inside.
    The only problem with both solutions is how to keep the bin or crate from sliding around. Maybe screw some suction cups to the corners?
    You would also have to check the crate out to make sure there isn't exposed metal on it. Some are all plastic but I'll bet there are some that are not.
    Default pool steps
    Hi all,
    Thanks so much for the great ideas!
    Last summer I tried putting a big plastic tub in the pool with cinder blocks inside. I wasn't able to find the right size tub. There's a slight angle at the floor of the pool, so no tubs would sit closely enough against the pool wall and the dog wouldn't cooperate by taking the wide step. Suction cups, however, to hold it in place are an excellent idea! I'm going to try a couple of things, including this again.
    I really like the idea of the extended step on the ladder. Very clever! I have the standard style ladders - kind of the shape of an elongated C - the top end sits into holes on the pool deck and the bottom rest on the side of the pool (picture found here: http://www.poolsinc.com/la_igss.html). The water is 3 feet deep there, so this could work. I can't figure out what material would be strong enough and, more importantly, what could I use to secure it onto the ladder step?
    What about a ramp? What material would work okay?
    Thanks a bunch,
    Lizzie
    rferrel1 Guest
    Default Dogs & liner pools??
    i'm a little confused - new contributor here - actually in the process of deciding between a Sharkliner or an Artesian AG pool. CAN dogs swim in liner pools? Is it enough to teach them where and how to get up. You mention that your dog is a big dog - mine are labs??
    Just really curious here. I would love to be able to let my dogs in the pool when I'm out there with them!
    waterbear's Avatar
    St. Augustine, Fl
    Default
    I have 3 small dogs, Yorkie, Miniature Schnauzer, and longhaird Daschund and non of mine can get up the pool steps without help. I have seen an inexpensive exit ramp for dogs and cats called the the Scamper Ramp that I have been considering. Does anyone know anything about it? The idea of weighted plastic crates sounds good but it would take up a lot of space in my small pool. I am open to any ideas or suggestions myself!
    Hurst, Texas, USA.
    Thumbs up
    Quote Originally Posted by rferrel1
    I have a vinyl lined pool and I also have a lab. She swims in the pool everyday with no damage to the pool at all. If your lab is as smart as most then you probably won't even have to show her where to get out, I didn't. Of course, our pool has steps.
    We have a lot of fun with her. We'll throw balls into the pool and watch her get a good steam up and launch herself into the pool. It's hilarious and she likes it too.
    Default
    I've never had any problems with the dog and the vinyl liner. My dog is a Chesapeake Bay Retriever (about 74 pounds) and she swims in it more than anyone else!
    If you want the dog to use the pool, make sure you get one with built-in steps - like I said, my dog can't get out by herself. Anything I get now will either be A. Expensive or B. Unsightly or awkward. I've taught her to rest while standing in the shallow end, but if she somehow got into the pool without us around, there's a serious chance she would drown. She will swim for hours upon hours - which, as you can imagine, leads to exhaustion.
    I also bought the Skamper Ramp - it was way too flimsy for my dog, even though I bought the extension for larger dogs. It would probably work with the smaller dogs, though. I keep it in the pool to save small animals that fall in the pool. I'm pretty sure it works because before having the Skamper Ramp, I used to find dead squirrels, rabbits, snakes, etc. fairly often, but none since I got it. It is definitely NOT for medium to larger dogs - maybe in an emergency.
    Any other thoughts on makeshift steps or ramps for the dogs?
    kaybinster Guest
    Default
    I have two siberian huskies that love to go swimming in the pool. They have never hurt the liner, but we have built in steps that they use with no problem. I had a tech come work on my hidden fence (keeps the dogs on the property) and he brought his lab with him. That dog was amazing. He would jump about four feet in the air and dive into the pool. What was amazing was he did not use the steps to get out, he knew how to climb the ladder! Now that is some smart dog.
  1. next steps for well water pool?
    By 33feet in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-14-2012, 02:55 PM
  2. Pool Steps
    By tnalaskan in forum Pool Equipment & Operations
    Last Post: 04-01-2012, 09:33 PM
  3. inground pool steps
    By heatherc in forum In-Ground Pool Construction and Repair
    Last Post: 06-06-2010, 07:31 PM
  4. Question about pool steps
    By poolio123 in forum In-Ground Pool Construction and Repair
    Last Post: 08-22-2006, 05:30 PM
  5. Algae under pool steps
    By AnnaK in forum Dealing with Algae & Slime
    Last Post: 08-06-2006, 10:59 AM
