While waiting for my PS234, I bought the walmart $15 drops-based test kit (under the brand "Aqua Chem" in a blue box). While opening the kit, I noticed what looked a lot like black dye or ink leaking. After opening, I discovered that it was the "Harness Solution A" (a very dark liquid) that was leaking (and staining everything it touched).
Anyhow, I figured no huge deal, so I lost 30 or 40 drops of the stuff, I still had over half the bottle left, enough to tide me over until PS234 arrives.
The first time I tested CH, it read 0. That is, I put two drops of the dark solution into my test water, and it remained clear. The instructions say a "violet color will develop if hardness is present" (as an aside, I find it funny how harness can be "present"). Anyway, I figured it meant I had low CH (even after adding 5 lbs to my 14000gal pool a few weeks ago after initial startup (pool was just finished a month ago)). So yesterday I added another 4 lbs of calcium chloride and ran pump all night. This morning, I just tested it again, and nothing! No violet color in the test tube. I was like WTF? So, I added 10 or 15 granules of calcium chloride to the test tube, swirled, and tried again. The "Hardness Solution A" didn't do a darn thing to the test water, no violet color developed. Surely putting Calcium Chloride directly into the test tube would "present" some "hardness" to the water. So is my CH test solution defective? Did it somehow get worn out when I found it leaking??
We have a new propane heater installed, and will be fired for the first time on Tuesday when the gas company fills the tank, so I want to make sure CH is at a reasonable level, as I have read that incorrect CH (too high or low) can hurt equipment, esp. heater cores.
