Thread: Above ground Intex 15 ft round pool - take down or winterize?
    Jun 2010
    South MS
    Question Above ground Intex 15 ft round pool - take down or winterize?
    We have the 15 foot round Intex pool with the metal frame, that is about 4 foot deep. We live in South MS. We usually only get a few freezes a year, and they don't usually last for more than a few days at a time. DH says we probably get a total of 14 to 16 days below freezing all winter, and it is extremely rare for our temps to go down into the teens. Usually the lowest we see is mid-20's. With all that being said, is it better to take down the pool or winterize it? DH wants to leave it up but empty, but from my understanding, that isn't a good idea either. I'm not so sure about having to take it all down, and then risk holes being in it when we go to all that work of putting it back up again (and it was quite a bit of work, as DH's dad had a load of sand delivered and DH worked really hard to make it level). Also, if we take it down, I can envision it turning into a giant litter box for the cats around here (including our own). However, DH also doesn't want to have to go into a lot of trouble maintaining it over the winter.
    We do have a large container of Polyquat and can get more if needed.
    We haven't been swimming much lately and have been a bit less diligent with the pool. DH noticed a bit of green algae on the bottom of the pool a couple of days ago and shocked the pool.
    We've just had our first cool front come through and are expecting temps down into the upper 50's/lower 60's this week, with highs in the low-to-mid 80's (with one day up to 87). At what temp do you decide it is time to put the pool up for the winter? The pool temp was just 80 degrees the other day, and it may yet warm up down here to swimmable again a time or two. Also, do those solar blankets really help?
    One last question, if you do winterize, with the temps we expect over the winter, do we need a winter cover? We just have the cover that came with it. We actually used that cover when we went on vacation and somehow it fell into the pool. However, as long as we are actually here, hopefully we can do a better job of securing and watching the cover.
    Sorry for so many questions, and thanks so much for any advice you can offer!
    Tricia from South MS
    Intex Above Ground Metal-Framed Pool 15' x 48" (~5000 gallons) installed 6/21/10, and now using BBB (well only one of the B's so far) and Taylor K-2006 test kit
    Default Re: Above ground Intex 15 ft round pool - take down or winterize?
    I live near Shreveport, LA, which is not far from you, and we pretty much get the same weather you do. My IG pool has never been closed in its 8-year life!! You'll find that your chlorine consumption goes way down when the water gets cold, and algae can't grow nearly as fast, either, so it doesn't take as much time or bleach to maintain it over the winter as it does over the summertime. I just decrease my pump run time to 3-4 hours a day, and don't get upset if I miss a few days here and there--but anytime the air temp is supposed to go below 29 degrees I just run the pump overnight, and keep it running until the air goes back above 30. It has worked very well for me--and it's really nice in the springtime to just wait for the water to get warm enough to swim in, and not have to worry about cleaning up a mess from over the winter!!
    I don't cover mine, because I don't have any trees around it, but if you have trees or animals/people that are likely to get into it over the winter, then I would use a cover of some type. Definitely remove your ladder.
    Just my $.02...
  1. 15' round mystic pool above ground
    By Kiddo44pct in forum Intex-type Pool Setup & Operations
    Last Post: 07-13-2012, 12:36 AM
  2. bottom drain for 33 round above ground pool
    By kimkats000 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-09-2012, 08:02 PM
  3. Pool Install for 22x54 Round Intex
    By Soybomb in forum Intex-type Pool Setup & Operations
    Last Post: 04-23-2012, 10:01 PM
  4. Over 1 week after above ground pool installation, AGP 24' round, bottom still soft...
    By ejacoby1 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-10-2011, 11:41 PM
