Results 11 to 17 of 17
Thread: Pump Efficiency
    California
    Default Re: Pump Efficiency
    Mark,
    So with the 4x160 I would set up two programs, one for solar on that had an RPM that produced a GPM of 48 (that I must calculate from the pump curves and my pressure reading converted to head in feet plus add the estimated suction loss), with the other program for solar off that was set for a worst-case of 8-hour runtime (since that's how long my solar could effectively be used for heating) for 1 turnover which is 16,000/(8*60) = 33 GPM. I would switch between the two automatically based on my existing solar thermostat (which already outputs to a Jandy automatic switch so could also output to the 4x160 via IntelliComm).
    With the full IntelliFlow, the "filter" program would be set at 33 GPM while I would have a "feature" for the solar that was set at 48 GPM and would be triggered (via IntelliComm) by the solar thermostat. So my worst-case energy waste with the 4x160 vs. the full IntelliFlow is when the solar is on for a full turnover, so 16,000/(48*60) = 5.5 hours at which point, assuming the water is warm enough (so that the solar shuts off), the Intelliflow shuts off completely for the day. That comes to an energy waste with the 4x160 of (8-5.5) = 2.5 hours running at 33 GPM. This is probably a few hundred watts so about $6 per month or so.
    Of course, with the full IntelliFlow I also get the flow meter so don't have to try and estimate (possibly inaccurately) my flow rates using pump curves and the pressure gauge. And it will be more flexible if flow rates change for any other reason.
    Whichever way I go, this will really make that booster pump for the Letro Legend really stick out with its wasteful 1470 Watts, even though it doesn't run as often. I can't even use another IntelliFlow 4x170 for this application since it apparently requires 50 PSI (115 feet of head) at 12 GPM. It's really too bad there isn't a more efficient pump for this purpose. I've looked at vacuum cleaners instead, but they vacuum to my filter and not to a bag so that's a hassle for cleaning. I've also looked at automated cleaners (probably the most energy efficient option), but they require a 24V power cord going into the pool which is a separate hassle. About all I can do is to reduce my cleaner run times as much as possible, unless you have some suggestions.
    Richard
    P.S.
    I thought of another reason why the flow-metered IntelliFlow would be better. In my calculations for the solar, I was assuming steady state, but in fact during the priming of the solar an additional 15 feet or so of head is present and that would require a higher RPM to attain (even at a lower GPM -- the curves are somewhat "flat" at constant RPM), but this extra RPM (and energy) would be wasted (and lead to higher flow rates than needed) once priming was completed. Looks like the full IntelliFlow is the way to go for my system.
    mas985's Avatar
    mas985 is offline Lifetime Member Whizbang Spinner mas985 3 stars mas985 3 stars mas985 3 stars
    Pleasanton, CA
    Quote Originally Posted by chem geek View Post
    Mark,
    This should work but if you want to have the same flow rate for solar on or off, then use this formula:
    RPM solar on = RPM solar off * sqrt (Head Solar on / Head solar off)
    This will force the flow rates to be nearly the same and thus the run times to be the same as well and should be just as efficient as the IntelliFlow just a bit more work setting it up.
    With the Intellifow I would just set it for one flow rate and it should automatically adjust for solar on or off to maintain the same flow and thus the same run time.
    Yes, the 4x160 only has four settings which might be enough but the Intelliflow is easier to set up and more flexible for various situations.
    You can add a leaf trap to the vacuum line which collects the leaves before they enter the pump basket. I have one for mine.
    If I had to do it all over again, I would have gone with a Robotic. The 24v line is much easier to deal with than either a pressure or vacuum line.
    Richard
    P.S.
    Actually during priming dynamic head builds very slowly as the pipe fills. So when the water gets to the roof, you only have half the dynamic head and as the water falls, you lose the static head and gain the other half of dynamic head.
    Net Net, priming total head will be much lower than full flow head. To prove it to yourself, watch your filter PSI as you go from no solar to solar.
    See Comments Above.
    Mark
    California
    Mark,
    Thanks again for your wisdom and great advice. Before I got your response, I took a look at the IntelliFlow pump curves and came up with the following formula that tracks very, very well with the curves:
    Head = (RPM/350)^2 - (GPM^2)/470
    This essentially reduces to the formula you gave, if comparing two different Head/RPM combinations, assuming that the GPM is 0. The above is more accurate when there is a non-zero GPM, but because the curves are relatively flat this isn't a huge difference at low GPM.
    For the 4x160, I intentionally wanted to use different flow rates for solar on and off since the solar on required 48 GPM for its solar panel efficiency while the solar off had no such requirement so could use a lower GPM of 33 worst-case (i.e. 8-hours) and this lower GPM (and RPM) should result in lower power and energy cost. This assumed that I always ran the pump for 8 hours since that is how long the solar could effectively be used to heat the pool. I understand that a single flow rate is simpler, but it's also (somewhat) more expensive.
    For the full IntelliFlow, I can see how setting a single flow rate is easy (and I wouldn't need the IntelliComm in that case) and that the IntelliFlow can cut the runtime to only do a single turnover, but there could be a case where it goes for 5.5 hours without the solar and then turns off (because that's one turnover with the 48 GPM rate that I must have to make the solar efficient in case it comes on), but then the sun comes out and there won't be any solar heating because the pump is off. That's why I wanted to hook in to the solar as a "feature" to be able to force the pump on. So while I had two situations anyway (solar on and solar off), I figured to minimize the energy usage in the most extreme cases with two different GPM rates.
    I understand the simplicity of a single flow rate, but thought I'd get away with lower flow in the solar off times because, well, because I can. In fact, I don't have to limit myself to 8 hours in that case and can have the pump "enabled" for the full 24 hours since I know the solar won't get triggered except during the day while the pump could use a VERY low GPM over up to 24 hours until one turnover is achieved. What I don't know (yet) is at what point a low GPM becomes less energy efficient where the longer time takes more energy than is saved by the lower GPM (and lower frictional losses). I don't have a good formula for the "power" curves except that it's about 50% of output power (proportional to product of GPM and Head) above about 40 GPM at low RPM and above 80 GPM at the highest RPM (at very low RPM, efficiency goes to hell regardless of GPM -- probably due to electrical and motor efficiency losses, so clearly using a very low GPM does not make much sense).
    A leaf trap to the vacuum line -- BRILLIANT! Jeez, I wish I had thought of that, but am glad you did. It seems that the requirements for a vacuum unit are much less stringent (it would appear that they require 25 GPM) and I could probably then have an automatic valve switch to use the vacuum cleaner on suction (instead of the skimmer) and the flow rate could be set to whatever is needed for that feature (hopefully, the same 48 GPM that the solar uses would be sufficient, though this is cut down due to sharing the suction with the floor drains which are on a separate line until we get close to the pump; also, the line to the cleaner is 1.5" instead of 2" so the losses will be greater than on the floor drain line). If I wanted to figure out approximate flow rates for these two lines that are branched together at the suction side of the pump, how do I do that? I can estimate friction losses from the pipe, but how do I know what losses or restrictions there are at the floor drains and skimmer? I know that the negative pressure at the pump side must be the same between the two lines (though their GPM will clearly be different due to different line sizes) and can calculate the less negative pressure as I move through the line, but do I just assume no resistance at the opening to the pool and just assume the flow rates are related to the size of the line (i.e. assume the suction loss is the same in both lines and work backwards to calculate the GPM in each line that would make that happen)?
    In terms of using a robotic cleaner, I don't think I can get away with having a cord on our hardscape to go into the pool -- my wife is picky about those things. And removing the robot might be more of a pain, though maybe it's about the same as pulling out the pressure (or vacuum) cleaner -- right now we just put the line that was in the pool over onto our coping and keep the sweeper unit in the corner at the deep end while we use the pool. What problems do you have with your vacuum cleaner or using a vacuum line?
    Thanks for the explanation of priming. That makes perfect sense to me.
    I feel like breaking out singing, "I'm so excited....and I just can't hide it....I know, I know, I know, I know, I know I want IntelliFlo...I want IntelliFlo". OK, so my rhythm sucks.
    Richard
    mas985's Avatar
    Pleasanton, CA
    Richard,
    Something does not look quite right with that equation. From the pumps perspective, GPM and Head are inversely proportionate while GPM and RPM should be proportionate. Also for the pump, GPM is the dependent variable and Head is the independent variable while for the plumbing system it is the opposite.
    Here is the way I would formulate the problem using first order approximations. Note that second order effects do create some error in this methodology.
    Starting with the pumping efficiency equation (note this is slightly different than the energy efficiency equation):
    Eff = Head * GPM / (BHP * 3960)
    and from pump affinity equations:
    Effective BHP = BHP(max) * (RPM / RPM(max)) ^ 3
    So solving for GPM
    GPM = A * (RPM / RPM(max)) ^ 3 / Head
    where A = (Eff * BHP (max) * 3960) but this can be solved for using the head curves for the pump. So for the 4x160, using 60' of head is about 100 GPM, A = 6000. A will vary some with head (second order effects) but for now we will ignore that. Also, we can test the formula for other RPMs. @ 2350 RPM and a Head of 40', GPM should be about 47. It's tough to tell from the chart but it looks about right. So this formula should work for all RPM and Head values of the pump.
    Now, your pool plumbing has the relationship of:
    Head = B * GPM^2
    Where B can be found from the operating head and GPM. For without solar, you originally gave the head and flow rates as 45' @ 90 GPM so B = 1 / 180.
    Combining the equations gives you
    GPM = (A / B) ^ (1/3) * (RPM/RPM(max)) = 0.02974 * RPM
    This is a single formula which characterizes both your pool and the pump together. Since the pump goes from 3450 to 400 RPM, your GPM should range from 12 up to 97 which is a great range to be able to operate over. Heck, I might go for one of these too. At the lowest rate, you could have a 24 hour turnover which is fantastic! You really never need to shut off the pump and when the solar goes on, you will just need to bump up the flow rate some. The value of B changes for solar so you can use the appropriate number. Also, if you need two turnovers a day, you can adjust the pump for 24 GPM and still run for 24 hours.
    Let us know what you end up with.
    Mark
    California
    Hi Mark,
    GPM and Head go in opposite directions which is why there is the minus sign in my formula, but they cannot be inversely proportional since the pump curves show a positive non-zero head with a GPM of 0. This is where the pump is spinning just to generate equivalent pressure against the head -- or another way of looking at it is that as much water is pumped towards the head as is leaked backwards so that the net GPM is 0. Your formulas don't work for that, unless I'm misinterpreting them. The formula I gave almost exactly matches all the pump curves (within 1 or sometimes 2 feet of head) for both the full IntelliFlow and the IntelliFlow 4x160 (except the latter appears to have a mistake labeling the 750 RPM which appears to really be 950 RPM).
    Anyway, I'm going to call my pool contractor to see if they can do the work to replace my pump and I'll very likely go with the full IntelliFlow. I'll keep y'all posted as to my results after it gets installed.
    Thanks,
    Richard
  6. #16
    mas985's Avatar
    Pleasanton, CA
    Richard,
    Maybe I need to clarify my methodology a bit better. My original intent was to model your pool and pump together and not to match the entire pump curve. Pump curves handle both static and dynamic head but most pools have mostly dynamic head (i.e. pool is not much lower or higher than the equipment pad). Therefore, under normal operation after priming, you will never see a condition where the head is high but the flow is near zero. So I originally modeled the pump at maximum RPM and head between 60'-80'. This should be the range that your pool operates within at that RPM. I could have done a polynomial fit but it was unlikely to offer much more accuracy.
    However, going back over the formulation, I made an error calculating the constant A. At 60' of head, the pump puts out 136 GPM and not 100 GPM.
    To show how well the approximation holds, I made simple spread sheet. Here are the results:
    HTML Code:
    Head @ 3450 RPM	60	70	80	90
    Actual GPM	136	117	97	60
    Approximate GPM	137	117	102	91
    Richard's GPM	132	113	90	58
    Head @ 2350 RPM	28	32	37	42
    Actual GPM	93	80	66	41
    Approximate GPM	93	80	70	62
    Richard's GPM	90	77	61	40
    Head @ 1500 RPM	11	13	15	17
    Actual GPM	59	51	42	26
    Approximate GPM	59	51	45	40
    Richard's GPM	57	49	39	25
    The head ranges are scaled with RPM to stay withing the main part of each speed's head curve. So you can see that the approximate GPM is not too bad and good up to about 80 feet of head @ 3450 RPM. It is unlikely a pool would be much above that anyway. So both your's and my methods have errors but in different locations.
    The other thing I would change about the formulation is to make the constant A independent of RPM which would be
    GPM = A * RPM ^ 3 / Head (Pump Formula)
    Where now, A = Head * GPM / RPM^3 of a particular sample point from the head curve. This makes the formula good for a range of head and all RPM values.
    Also, the pool plumbing equation, Head = B * GPM ^2 comes from the Darcy-Weisbach hydraulics equation relationship between head and GPM so the accuracy is pretty good.
    So with the above corrections the new formula for your pool is
    GPM = (A/B)^(1/3) * RPM = .033 * RPM or a range of 114 GPM down to 13.2 GPM.
    I just wanted to make sure you understood what I did.
    I also want to add that using your pump formula along with the plumbing formula and solving for GPM:
    GPM = 1 / 350 / (B+1/470)^(1/2) * RPM or
    GPM = .033 * RPM which is the same as using my pump formula.
    Mark
  7. #17
    California
    NOTE TO MODERATORS:
    Could you please move the posts from #14 (somewhat arbirtrary, but I think that's a decent break) on to this thread I started in The China Shop? We are getting more technical than we should be for the general forum, but I do want to continue the discussion in a "safe" place that won't scare off newbies. Any net results, simple rules, or other useful information will continue to be posted in this thread, but the mathematics of fluid dynamics and statics and pump efficiencies will be kept out of this thread and placed in The China Shop.
    Thanks,
    Richard
  1. Filtering out dead algae and determining pool system efficiency...
    By Winglessflight97 in forum Pool Equipment & Operations
    Last Post: 05-09-2011, 11:21 AM
  2. Punp speed & SWCG Efficiency
    By RochesterMark in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-24-2010, 10:45 PM
  3. Clorox High Efficiency bleach???
    By mariner09 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-05-2008, 06:22 PM
  4. Pump Efficiency, Head, Flow, and related technical info
    By chem geek in forum The China Shop
    Last Post: 02-02-2007, 12:39 AM
  5. Spa Heater Efficiency?
    By cygnusecks in forum Pool Equipment & Operations
    Last Post: 05-10-2006, 09:29 AM
