Re: sand filter problems
Hi Greg and welcome to the forum.
It is definitely possible for the pressure to climb fast when it's filtering a lot of stuff. Also depends on what kind of stuff. If it's larger particles then they will get trapped at the very top of the sand bed and raise the pressure pretty quick. When you backwash if you can look at the stream being dumped that will be a better indication of the amount of crud being collected than the sight glass.
