#1
Hello, we currently have a Jenair pump for our SW pool that is about 3 years old. I believe that in the summer when we run the pump about 6-7 hours (in So. California), our energy bill is about $150 extra.
I'm considering installing a pool pump to lower our energy bill. I see some Pentair models can bring the cost down to around per month. Any advice, return on investment time, costs, vendors? I'm not sure where to start researching. |
#2
This spreadsheet compares the energy consumption of many different pumps. You will find that the VS pumps are the lowest energy users with two speeds not too far behind. Column M is the metric to look at. It gives you a direct relationship between gallons pumped per watt-hour used.
__________________
Mark 18'x36' 20k gallon plaster/gunite pool, 1/2 HP 2sp pump, Aqualogic PS8 SWCG, 420 sq-ft Cartridge Filter, 480 sq-ft EPDM Solar Panel, 6 jet spa, 1 HP jet pump, 400k BTU NG Heater Hydraulics 101; Pump Ed 101; Pump Modeling Tools; FSEC Solar Panel Information; Solar Heat Gain and Loss |
| Thread Tools | |
| Display Modes | |
