Thread: 1 year after conversion
    Default Re: 1 year after conversion - Update after Year 2
    With two full years after the conversion under my belt, I am still 100% happy with my decision.
    In fact, the results are far better than I anticipated.
    It is so darn easy now. And SO much cheaper.
    I spent well under $100 all this past year on chemicals. That was for some generic bleach, calcium, CYA and maybe something else I can't remember now. This is a small fraction of what I spent the last year I had Baquacil (Around $1,400).
    But even better are the results.
    Every single day since that SWG was installed, my pool has looked and felt great. No algae. Never cloudy. Always feels nice. Doesn't irritate eyes.
    My son swims with his eyes open, and it never bothers him. He doesn't even realize that most people don't do that for any length of time. It's just natural for him.
    I have a good test kit, and I test frequently at the beginning of the season while the pool is settling after winter. I might add some bleach to shock if needed. Maybe some calcium and also some salt to replace what I pumped out to lower the level going into the winter. And some CYA.
    But then, I test maybe once per week. Reason is, the levels are so consistent, that I don't have to add chemicals.
    Some details: New England, very sunny exposure. IG gunite pool around 30,000 gallons. I have solar water heating and keep the temp around 84 degrees because that's where my kids like it.
    SWG is a Mineral Springs system. Paid around $1000 for it. Cell still looks brand new after 2 full years. I run the filter 24/7. Will probably experiment with running it less this year, so that might involve some tweaking with the SWG setting.
    Also - I do NOT use the Mineral Springs Renewal or any chemicals they recommend at the store. The salt I add is pure rock salt I get for around $4.00 per bag at Lowes. I do this once or twice per year to replace the bit that gets splashed out.
    The Renewal chemicals they try to sell at the pool stores add additional chemicals beyond salt. But you don't know exactly what or how much is being added. Since I currently add almost nothing, why would I need anything extra to be added? Answer; I certainly don't. And that Renewal stuff is expensive, while pure salt couldn't be any cheaper.
    So - get an SWG but don't add their chemicals. Use pure rock salt.
    Summary: Combining a SWG with an AquaBot results in an absolute minimum of pool maintenance. I easily paid for my SWG system after one year, and then saved another several hundred dollars the second year.
    But more important, it's easy and the water looks great. It has made my pool far more enjoyable by improving swimming quality and aesthetics while at the same time making maintenance easier.
    Even after having pool parties with 20+ kids in the water, I might add a gallon or two of bleach for some shock value, and the pool remains crystal clear.
    Hope this helps,
    Jeff
    Update -
    It's now been 4 years I've had the SWG. Still love it!
    I now run the filter 10 hours a day from about 10 in the morning to 8 at night. This is primarily to circulate the water through my solar system and get the heat.
    I should mention that I have a solar cover and cover the pool at night.
    This year, when I opened my pool, I added one gallon of shock. Haven't needed to add anything else since, and the pool is crystal clear.
    Anyone looking for the minimum in pool maintenance should consider the combination of SWG and a unit like the Aquabot.
    I pretty much don't touch my manual pool vacuum after the first day I open and get out the heavy stuff from over the winter.
    From then on, I throw in the Aquabot maybe once a week and it keeps the pool clean with no effort on my part.
    At this point, I don't even test very often because the pool is so stable.
    My SWG has a display that tells me the temp and salt levels, and I've found that the salt is accurate, so I don't use the chemistry for that much any more.
    I will add some calcium soon to get the hardness up a bit. Other than that, it's good.
    Overall, I am still extremely satisfied. I should note that I am still using the original cell with the SWG.
    A lite is now on that says to service the cell, but when I checked, the cell is perfectly clean.
    I know it is working correctly because the chlorine levels are stable.
    I wonder if that lite comes on due to "time in service", because it certainly doesn't seem to be less effective in its operation.
    I'm not going to lay out money for a new cell until this actually stops working.
    When I purchased the unit, I was let to expect that there is a 3 year or so life on the cells. I am well past that now, and it is still working fine.
    Ft Lauderdale, Fl
    Great info and fantastic review. Glad you're happy with your salt system.
    Do you run your pool year round or do you winterize?
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
    I'm in New England so it is seasonal.
    Update: Took the cover off to nice, clear water yesterday. Aquabot and filter doing their thing. It's 56 degrees so too cold for SWG yet.
    Jeff
    Default Re: 6 years after
    Well, looks like my Mineral Springs ms-11 has died.
    I have a -PCB- displaying on the readout. I called Mineral Springs tech support and they told me it needs a motherboard. This, in combination with the fact that the cell has been through 5 seasons, means that I need a cell and a motherboard. Which will likely cost me more than a new unit.
    This is possibly my own fault. The tech told me the MS-11 should be on the same timer as the filter. It was not. Since I am running the filter for about 9 hours per day now, it means the MS-11 is powered for 15 hours without any flow. Apparently that MAY have caused the problem. Or maybe it was a power surge. Or maybe the unit just doesn't last that long. I can't know for certain, but I do know the warranty back then was 5 years and I am well over that. (Now the warranty is 3 yrs)
    So - you may be wondering what I will do?
    I'm going to buy another one.
    I figure that first, I will fix the power issue so I'm not running it when the filter isn't on.
    Second, the unit costs around $1,000 online now. If I amortize that over 5 years, $200 a year, I am satisfied with that. Of course, I expect the motherboard to last more than 5 years after I fix the timer issue.
    For $200 a year, I am satisfied that the system was worth it. If another unit fails after 5 years, I will revise my opinion. We'll see.
    I should note that before the unit went on the fritz, my pool opening went very well and within a couple of days it was crystal clear.
    Jeff
    June, 2011
    Bosch232 is offline Registered+ Thread Analyst Bosch232 0
    Aug 2012
    Nebraska
    This thread should be stickied, it's a great read.
    16x32 Oval AG vinyl pool; Media Master sand filter; 1.5 hp 1 speed pump; 10 hrs; Rural utility water; Taylor K-2006
  1. Replies: 3
    Last Post: 05-21-2013, 03:16 PM
  2. first results of year, re-filled pool end of last year
    By vinouspleasure in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-23-2012, 04:54 PM
  3. conversion
    By chalk2024 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-20-2006, 11:47 PM
  4. conversion
    By bwalsh1 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-27-2006, 02:33 PM
  5. Opening - Last year, a nightmare. This year, perfect...??
    By bcb1 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-30-2006, 10:01 AM
