Re: So, am I ready to ROCK???
chem geek
I don't have a salt cell, but even at full power and running 24/7 you are right that the increase in chlorine levels attained in the pool will be much slower than dumping liquid chlorine into the pool. However, if one is starting from an existing free chlorine level then whatever chloramines that would have been formed have already done so.
If the organic load is higher than the chlorine available then more chloramine would form as the chlorine was increased, correct? From my understanding it is only after all the ammonia and organics present have combined that breakpoint can be reached.
Free chlorine combines with ammonia very, very quickly to form chloramines. It is the next steps to breakpoint that are slow (and free chlorine oxidizing organics can also be slow). So from a chemistry point of view, I don't think the slow increase in FC from a salt cell would be an issue unless the FC were at or near zero for some reason -- perhaps if there were a major ammonia (i.e. urine) accident that overwhelmed much of the free chlorine in the pool, remembering that you need about 10 times as much FC to achieve breakpoint as there is ammonia.
My understanding of the chemistry is that incomplete breakpoint (from a slow rise in chlorine) would favor the formation nitrogen trichloride (even at higher pH) and if the organics are from complex sources such as algae and not just ammonia (which is often the real world case when we 'shock') then it would cause the formation of other disinfection by products such as organochloramines, which are difficult to break down. Also reaction would not go to endpoint, which would be the release of nitrogen gas as the ammonia is broken down but cause the formation of nitrates in the water, which are a souce of food for algae.
[EDIT] In the presence of CYA, the breakpoint chlorination process is slowed down considerably since CYA reduces the disinfecting chlorine concentration. A normal breakpoint at an FC of 2.0 ppm with no CYA takes around 30 minutes to effectively complete so with 30 ppm CYA this would take about 11 hours if there was no sunlight. I don't know how much faster breakpoint goes with sunlight. [END-EDIT]
Once again this seems to indicate that the slow rise in FC caused by superchlorinating with the cell is not an effective way to reach breakpoint.
Richard
Your thoughts on this would be appreciated....perhaps in the China shop?
