Results 1 to 10 of 228
Thread: Clear, but no chlorine???
    BigDave's Avatar
    Default Re: Clear, but no chlorine???
    I just re-read about the Tuesday pool party - perhaps you should wait until after the party to shock. In that case, pour 5 jugs 8.25% and be ready to add more. Test FC/CC twice daily (early morning and evening). Add bleach as needed to keep FC at 15. If it drops below 8, test / dose more often. FYI each jug of 8.25% bleach will add about 3ppm FC to your pool.
    Don't add any more tabs to chlorinator.
    I just noticed that you pH is a little low - Add a box of Borax (20-Mule Team - laundry aid). You won't get accurate pH readings while FC > 10.
    Keep us posted.
    P.S. Why do you cover the pool at night?
    BigDave's Avatar
    OOPS! I thought you said pool was 26K gallons - 15K is different.
    I'll post again in a minute.
    Jul 2013
    Northern Illinois
    BigDave: while you're calculating, is there any additional issue with her CH being so high (750)?
    mary jo is offline Subscriber Thread Analyst mary jo 0
    Aug 2014
    Batavia, IL
    Oh- I forgot to respond earlier to this: When I tested for CH it turned purple (after about 40 drops) instead of blue, so I just kept adding drops until I saw blue (with small particles of purple swirling around). I looked this up in the Taylor booklet and it said this is caused by metals (copper?) in the water… btw: My city water is supplied by 3 city wells treated at a city water plant, and is characteristically HARD. Alot of homes have water softeners.
    15K gal, 15x30 rectangular, in-ground, vinyl liner, Pentair ¾ HP Whisperflo on 24/7, Pentair Cartridge Filter(CCP240), Heater (gas), Automatic Pool Cover
    BigDave's Avatar
    Quote Originally Posted by mary jo View Post
    ... this is caused by metals (copper?) in the water ...
    Maybe it would be safer to add a half cup of bleach to the test bucket to be sure we can't force the metals out.
    BigDave's Avatar
    Quote Originally Posted by FormerBromineUser View Post
    I asked if that could be testing error
    @mary jo: Did you retest CH? Perhaps you should add a Tablespoon of Borax to test bucket to see if it clouds before putting it in the pool. Put something dark in bucket - you may not be able to see a cloud in a white bucket.
    BigDave's Avatar
    OK. So...
    To start shock, add 6 jugs 8.25% bleach to go from 0 FC to 30ppm FC.
    or
    To get through party first, add 3 jugs 8.25% bleach to go from 0 to 15ppm FC.
    Each Jug will add a little over 5ppm FC.
    I would add a half box of Borax.
    Also:
    Sorry about that! Your first post said "15,000 SF rectangular" then I scanned for a volume and, apparently, found FormerBromineUser's volume - My Bad.
    Aug 2014
    Batavia, IL
    BigDave: My daughter thanks you (as do I)!!!! I will do as advised.
    oh- Why am I super diligent (crazy) about keeping the pool covered- especially at night????
    Main reason I got a pool was for my youngest (I have 4) who has special needs. Also the main reason I paid big bucks to get an automatic pool cover. He loves water but can be impulsive and loves to get up early (4:30am) and get into trouble. Twice during pool construction (during excavation) he ran out and attempted to jump into the hole from our deck.
    But I read about the chemical build-up that occurs during shocking so I will be extra careful in keeping him away from the open water, and keep the cover open until this chlorine issue is resolved.
    thanks again.
    BigDave's Avatar
    With that safety issue, I would keep it closed and deal with the consequences. If there's damage, it's only money.
    Aug 2014
    Batavia, IL
    funny- that's what my husband always says….
    I'm a night owl so I can keep the cover open til about 2am, then close until morning.
    i have the test bucket with pool water & 1/2 cup bleach in it. Will let you know tomorrow what happens.
    thanks
  1. Clear Pool but cannot maintain free chlorine level?
    By Mr.Mooks in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2011, 08:47 PM
  2. high chlorine, but crystal clear!
    By katydid in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2011, 09:14 AM
  3. OK It's clear now what do I need to do?
    By joanie109 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-19-2006, 05:46 PM
  4. Clear solar cover options? Magni Clear?
    By PoBoy in forum Pool Equipment & Operations
    Last Post: 07-10-2006, 12:01 PM
  5. Pure and Clear SWG
    By superjet in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-23-2006, 12:30 PM
