Re: Bromine Chemisty Question
PoolDoc: I bought the borate LaMotte test strips as recommended. May I test borates with distilled water instead of tap? Our tap is softened well water....
ChemGeek: Your borax/volume ratios agree better with my results although it appears I am testing higher than 50. Maybe Ben can use your ratios to compare with his other "info sources". The placebo effect works for me if it makes my husband happy with my new water recipe: pool forum vs. pool store! But he is ADAMANT about the improvement since adding borax. I can't speak to it; 75 degrees is way to cold for me. I read that you use borates, Richard. Have you gone swimming in water without borates to see if YOU notice a difference? Just a thought.
