Results 1 to 10 of 12
Thread: Bleach instead of Chlorine tab for daily/weekly maintenance
    Default Re: Bleach instead of Chlorine tab for daily/weekly maintenance
    Yeah, if the water doesn't turn pink when you add the R-0003, your CC is 0.
    But save your reagents and don't test at 25ml, test at 10ml. Each drop is .5 and that's accurate enough.
    May 2014
    Thanks for the tip. Any reason for cc 0?
    New pool owner
    30,000 gallon concrete and tile pool with DE filter and offline Chlorinator.
    May 2014
    Are there any instructions on how to test with 10ml.
    I am assuming:
    10 ml of water
    1 dipper DPD powder (correct???)
    R 871 - drop wise - # of drops x 0.5 = FC
    R 003 - Still 5 drops (???)
    R 871 - drop wise - # of drops x 0.5 = CC
    Is that correct?
    New pool owner
    Yep. You got it!
  1. Daily Chlorine amount
    By tnalaskan in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-18-2014, 07:30 PM
  2. What is normal daily chlorine usage?
    By Electrikkoolaid in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-17-2011, 03:42 PM
  3. how much bleach do you use for daily use and to super shock
    By eartha in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-09-2010, 06:35 PM
  4. How many PPM of Chlorine should I lose daily?
    By keithw in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-10-2006, 06:06 PM
  5. Using Bleach as daily chlorine
    By golfwig in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-06-2006, 04:29 PM
